Old 04-17-2016, 07:24 AM
Vince GTO's Avatar
Vince GTO Vince GTO is offline
Default oil drain lines
Hello
Does anybody have pictures of external oil drain lines from round port e-heads. I also would be interested in where you went into the pan.
Thanks Vince
Old 04-17-2016, 09:21 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Post
couple pics in a stock frame 69 abody. You will probably need to mock it up to see where you can go into the pan with the headers you have. Bigger line the better...these are no 10.
ID:	426457   Click image for larger version
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 04-17-2016, 11:05 AM
So do you have a "Dam" to direct the oil to the drain hose fitting JC?
The early E-heads are easy as they have a pocket below the valve cover surface where the rear head bolt goes.
Old 04-17-2016, 11:41 AM
Vince GTO's Avatar
Not much room on the rear of the head from what I can see. I was thinking the same spot as JC?
mike leech's Avatar
mike leech mike leech is offline
I'll post pictures in a little bit
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 04-17-2016, 12:45 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Here's what we have.
Boobs & bacon
Old 04-17-2016, 12:58 PM
BADDTA's Avatar
I can't get the other side pic to upload!
Brian
Boobs & bacon
Old 04-17-2016, 01:13 PM
PONTYRAT1 PONTYRAT1 is offline
Default OIL DRAIN
heres my setup
ID:	426480   Click image for larger version
Old 04-17-2016, 01:19 PM
Default oil drain
other side
Old 04-17-2016, 01:43 PM
Vince GTO's Avatar
Thanks everyone for posting the pictures.
Vince
Old 04-17-2016, 07:08 PM
60man's Avatar
60man 60man is offline
Do you'll run diapers?
My diaper hugs the pan pretty tight at rail....
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 04-17-2016, 07:16 PM
I just used Swageloc fittings: 90 degree 1/2" id out of the heads, 1/2" hard tubing to the oil pan and 1/2" 90 degree fittings screwed into welded bungs in a custom steel oil pan.
http://www.swagelok.com/en/product/F...-Tube-Adapters
Working with aeroquip parts take up a lot of space needed on a clutch car.
There isn't a lot of oil that gets to the valve covers with Smith Brothers .080" restricted pushrods.
Old 04-17-2016, 11:54 PM
Probird's Avatar
Probird Probird is offline
I wondered the same thing. I just got mine in today with the new diaper. My heads are tapped for the oil lines but after looking at it I don't see any good way to get an oil line into the pan with the diaper on. Mine will stay plugged for now.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 04-18-2016, 06:27 AM
Vince GTO's Avatar
I have not considered a diaper yet just prepping to run it on the dyno. Thanks for something else to worry about! I am beginning to wonder why I do this. LOL
Old 04-18-2016, 06:55 AM
Vince GTO's Avatar
Default Diaper
Okay now I have to ask what brand diaper are you guys using?
Old 04-18-2016, 07:03 AM
Money Pit's Avatar
Money Pit Money Pit is offline
DRE diaper, Dennis is great to work with.
Old 04-18-2016, 08:00 AM
60man's Avatar
DRE. Dennis is great to deal with! 👍
ECM member.
MANDRA
Old 04-18-2016, 08:35 AM
ho428's Avatar
ho428 ho428 is offline
I run the restrictive push rods, seem to do ok.
I've thought about hard lines but I'd be concerned about vibration and fatigue.
Old 04-18-2016, 08:38 AM
Probird's Avatar
DRE here also. Fits pretty good. I don't know how I'm going to change the oil but it does fit well.
Old 04-18-2016, 01:02 PM
mike leech's Avatar
Fabricate a aluminum containment pan. Lots more room and a lot easier to work on
EHTTFMF!
