Old 09-26-2015, 07:26 AM
chuckies76ta's Avatar
That's some excellent times.. My wife ran a best of 11.20 at 118 mph yesterday.. Elevation was 2300 ft.
Charles
950 Quickfuel.
  #142
Old 09-26-2015, 08:11 AM
ta man ta man is offline
Charles
That's awesome...we had decent air but a pesky headwind..I've never ran quicker then 11.7/116 at this track...something is always up..nice to have the car finally run well..had quite a few friends down watching too!
  #143
Old 09-26-2015, 09:14 AM
Originally Posted by ta man View Post
Did testntune last night at Grandbend Motorplex ran three times..11.408 at 119.96 with a 1.731 60ft,11.457 at 118.82 with a 1.718 60 ft and a 11.435 at 118.73 with a 1.714 60 ft.
Last two runs were into a good headwind..pretty content with the times with the soft 60ft...a bit of fine tuning could drop the 60ft times.My fuel pressure also now drops to 3 lbs by half track which is an issue.
I did manage to outrun my buddy's Chevelle..we were betting on best timeslip for the night...he ran in the 11.5's with one slip at 11.45.He is 555 cuinch 110 octane 3.73 gears...
Hmmmm, I wonder if a fuel PSI tap on the output of a pusher pump (near the tank) would provide the best information?
  #144
Old 09-26-2015, 09:24 AM
Easy to do with a electric sender..
  #145
Old 09-26-2015, 10:23 AM
tpssonic's Avatar
tpssonic tpssonic is offline
Very nice.
Chalk another one up for team Pontiac. Keep on keepin' on ta man!
  #146
Old 09-26-2015, 06:53 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Nice job smacking down that BBC!
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #147
Old 05-09-2016, 09:45 AM
Planning on dragstrip testing a new Torker 2 ported by a fellow board member May 20th..intake has excellent flow and small runners..I have a couple pictures.The new intake has extensive plenum work.When I swap intakes in the next couple days I will take side by side photos for comparision.
ID:	428048   Click image for larger version
ID:	428049   Click image for larger version
  #148
Old 05-09-2016, 09:49 AM
ponjohn's Avatar
ponjohn ponjohn is offline
No welding needed on the T2 for 290 d-port?
  #149
Old 05-09-2016, 09:57 AM
Here is a picture without the 1233 gasket..The picture before was a 1233 gasket which is slightly larger than my head ports.
  #150
Old 05-09-2016, 12:26 PM
Pontiac Derek Pontiac Derek is offline
Sweetness!!! I can't wait!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #151
Old 05-09-2016, 06:49 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Any more pics of the plenum and plenum to runner areas?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #152
Old 05-09-2016, 06:58 PM
I will try and get some better pictures tonite when I'm in the shop.
  #153
Old 05-09-2016, 08:41 PM
grandville455's Avatar
Awesome!! I think I know who did it, you will love it !
Darby
M/T 275/60 ET SS Drag Radial
  #154
Old 05-10-2016, 02:22 AM
Will Will is offline
Those are some great times, and 3.08 gears... man, I'm envious!
  #155
Old 05-10-2016, 03:42 AM
A few more pictures..
ID:	428119   Click image for larger version
Name:	oring intake.jpg
ID:	428120   Click image for larger version
Name:	orig plenum.jpg
ID:	428121   Click image for larger version
  #156
Old 05-10-2016, 08:42 AM
77 TRASHCAN's Avatar
I hope the ported Torker II experiment works out better than the RPM deal...
Shut it off
Shut it off
  #157
Old 05-10-2016, 09:31 AM
Torquewar's Avatar
Torquewar Torquewar is offline
The 20th will be fun with TA man and CNC. The trio of second gens will make there presence known.
Darn weather better co-operate...
  #158
Old 05-10-2016, 10:31 AM
Ernie commented the other day you had been through a rebuild over winter, any changes?
Shut it off
Shut it off
  #159
Old 05-10-2016, 01:07 PM
Torquewar's Avatar
Yes some upgrades everywhere...$$$$ ouch.
Engine was refreshed because of some wear and cam bearings that fragmented.
So all bearings /rings and rollmaster chain with Simms mod. New RoMac Balancer
My SD heads received another port enchancment ...tubes now in ports.
Went to a Solid roller lifter so spring pressure was increased ...new crower vasco jets.
Trans was redone by the best guy around here...Hutch. Stock shifter gone now a B&M consol mount unit..love it.
Caltrack springs and Global West shackle kit.....big difference in ride quality. another oil change and its strip time. Have about 120 miles on it....happy happy.
SD is doing a T-2 for me and Shaker 455 has my carb done. That will be installed in June and will only be a race setup. My RPM and Quad still work great.
So lots of stuff going on and a learning curve on rear suspension set-up.
Eager to get at it with TA man....been over a year..
  #160
Old 05-10-2016, 02:25 PM
Yes for sure..I think it really came down to hood clearance issues...I run a one inch Wilson tapered Spacer and a 4 inch Spectre Cowl Air Cleaner..with a Torker 2...with the rpm..I could only run one or the other..giving up potential horsepower..I could feel the power loss on the street and it did slow down at the track.
This intake I couldn't pass up..last fall I was offered a deal on port work that anyone would take!
