Old 10-17-2017, 04:31 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Default th350 filler tube o-ring seal
I need to replace the filler tube o-ring on the th350 in the Bird. Is the fluid level below that point in the case or will I loose fluid out the filler tube hole? Thanks.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 10-17-2017, 04:45 PM
Seems like fluid level is above the o-ring with the engine not running.
I have changed them by jacking up passenger side only without making a mess.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 10-17-2017, 04:48 PM
ponyakr's Avatar
ponyakr ponyakr is offline
Mine had leaked down so that no more would run out. If I'd kept the car, I'd have swapped the tube for a FitzAll stick & tube, with the top hat type seal. My tranny guy told me about 'em. Says he has sold a lot of 'em. Says top hat seal works MUCH better than the single O-ring.
Or, if you wanna keep your stock tube, you can cut off the end & attach one of the top hat seal type repair ends. I think Cliff has mentioned using these. These parts are sold on Ebay, Amazon and probably lots of trans shops.
http://www.fitzall.com/filler_tubes.php
https://www.amazon.com/Universal-Aut.../dp/B00B40MPVM
http://www.ebay.com/itm/TH350-TH350C...ZRlSCr&vxp=mtr
http://www.ebay.com/itm/Filler-Tube-...JWp9SE&vxp=mtr
http://www.ebay.com/itm/Dipstick-Fil...-/300803616743
Old 10-17-2017, 07:37 PM
Thanks for the tips; may look into the Fitzall solution.
Old 10-17-2017, 09:43 PM
Mace1971's Avatar
Mace1971 Mace1971 is offline
Do you know how it’s attached? I didn’t see where the descriptions mention this. Welding, brazing or just a slip fit with sealant?
-- Kevin
1971 Trans Am, White/Blue
455 YC Block with Edelbrock Performer RPM Aluminum Heads, 10-10.5 estimated CR, E-Performer Plus cam (soon to be 041 + Rhoads), Comp Cams 1.65:1 roller tip rockers, E-Performer Aluminum Intake (soon to be topped by a FiTech EFI), TRW forged pistons, Hedman Husler Headers, 3" dual exhaust with Flow Master mufflers.
Old 10-18-2017, 08:01 AM
LeighP's Avatar
LeighP LeighP is offline
For info, the factory tube in my 69 Firebird's TH350 is the "top hat" style seal.....first time I'd seen one, my auto trans guy said they are a much better seal than the o ring.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 10-18-2017, 09:59 AM
ponyakr's Avatar
Now that's worth discussing.
I've seen a lot of factory tubes from the late 60's & early '70's. And I never even heard of a top hat seal, until recently, much less saw one on an original '69 tube.
So, are you saying that you have a '69 tube that came from the Pontiac factory with a top hat type seal ? Or is it a factory tube which has had the end changed over to the top hat style.
Old 10-18-2017, 10:02 AM
ponyakr's Avatar
Yeah, we had this discussion a few months back. I think Cliff said he brazed 'em on. But I reckin welding will work. Seems that I remember reading that some types can be attached with just sealer, like maybe some kind of good epoxy.
I'll do a search & see if I can find that thread.
Here's 2 of 'em.
http://forums.maxperformanceinc.com/...light=dipstick
http://forums.maxperformanceinc.com/...55#post5689355
Old 10-18-2017, 12:44 PM
Mace1971's Avatar
Thanks ponakr, I already have some Marine Tex so I think I'll go with the FitzAll repair part and give it a shot.
-- Kevin
