Old 10-29-2017, 01:39 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by slowbird View Post
If that balance hole offsets the gains from the alum rods, then the gain was so small it wasnt going to be noticable.
Besides that how does lighter rods increase performance?
The gains or losses from different reciprocating weights are usually small but real. Manual trans guys have played with flywheel weights for decades to increase their cars performance. It's kinda like the difference between power producing atmosphere and warm temperatures with lots of humidity and low barometric pressures.
Go fast, see Elvis!
  #42
Old 10-29-2017, 01:49 PM
slowbird's Avatar
slowbird slowbird is offline
So the lightest possible flywheel is always the quickest for stick cars?
  #43
Old 10-29-2017, 01:54 PM
slowbird's Avatar
Light weight has its benefits but 99.9% of the people won't realize those benefits. It just costs more money and increases maintenance.
  #44
Old 10-29-2017, 01:55 PM
PAUL K's Avatar
Not necessarily
Go fast, see Elvis!
  #45
Old 10-29-2017, 01:57 PM
PAUL K's Avatar
Why does it cost more money and increase maintenance?
Go fast, see Elvis!
  #46
Old 10-29-2017, 01:59 PM
AG's Avatar
AG AG is offline
Just picked up block etc for my brother's motor Friday. Eagle 6.625" rods, Icon forged pistons bob weight is 2190.6 g.
  #47
Old 10-29-2017, 02:56 PM
slowbird's Avatar
Not necessarily
But lighter is better isn't?
  #48
Old 10-29-2017, 04:24 PM
PAUL K's Avatar
Depends
Go fast, see Elvis!
  #49
Old 10-29-2017, 04:32 PM
Dragncar Dragncar is offline
There used to be a 56 chevy stick car that set a record years ago at our track. He had a very heavy flywheel, and a 265 small block.
Dan Whittmore about a couple of builds where the customer insisted on changing from steel to aluminum rods. Seen no difference. He generally did not like aluminum rods. Worrying about cycles and warming up your engine. Block heaters and all that. Had a customer who lived in cold weather and did not pay a lot of attention to warm ups, windowed the block.
  #50
Old 05-30-2018, 01:21 PM
grandville455's Avatar
So My New Combo is balanced and with the bigger bore, but lighter rings etc, its lighter then last combo just a tad at 2238 now..
Darby
M/T 275/60 ET SS Drag Radial
  #51
Old 06-01-2018, 10:24 AM
GTOGEORGE's Avatar
GTO George
  #52
Old 06-01-2018, 06:31 PM
vidguy's Avatar
vidguy vidguy is offline
On the 400 Paul Carter built For me:
Bob weight = 2332..
But do you know how far off each end of your crank is?
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
