Old 11-02-2017, 10:49 AM
500plus's Avatar
500plus 500plus is offline
Default 4bbl intake wanted
Hey guys, looking for a 4 bbl intake for my 61 4 cyl.
Thanks, Bill
Old 11-02-2017, 03:38 PM
Drag Star Le Mans's Avatar
So are you wanting the daul plane style or single plane?
DragStarLeMans
Old 11-03-2017, 08:06 AM
500plus's Avatar
hmm
I guess the 4 cyl is new to me...I didn't know that they offered single or dual!!
Old 11-03-2017, 08:57 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default intakes
The dual plane was used in 1961. A single plane was used in 1962-63.
Old 11-04-2017, 08:30 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
I forget, what is the difference? Better or worse what.
Old 11-05-2017, 03:58 PM
Peter Serio's Avatar
If your plan is to convert or build a fresh 195 ci 1bbl 4 cyl engine MAKE SURE that you get the carburetor and all the associated bits and pieces for the throttle linkage when you buy the manifold.
As far as I can recall none of that stuff is the same as the 1bbl carb intakes and if you don't buy a complete 4bbl carb with intake you will likely never find those linkage pieces. There may be other vacuum fitting(s), water outlet and/or wire holder; or aircleaner support brackets that go to a 4bbl intake as well. Best to buy a complete engine or at least the whole set-up rather than just a bare intake.
Peter Serio
Owner, Precision Pontiac
Old 11-05-2017, 04:38 PM
Peter gave some good advice. I don't have all the little bits just one of each. I'm going to dig them out and get pictures.
DragStarLeMans
Old 11-05-2017, 11:52 PM
Throttle linkage for the 61 daul plain 4bbl will be a problem. I doubt you would have any problems with the 62/63? I'm not desparate and my prices reflect that.
$160 shipped for the 61 daul plain unit and $120 shipped for the single plain 62/62 intake.
ID:	467032   Click image for larger version
ID:	467033   Click image for larger version
ID:	467034   Click image for larger version
ID:	467035   Click image for larger version
DragStarLeMans
Old 11-06-2017, 09:25 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Dual plane is a 61 only item. More torque from the 61 manifold. More HP from the single plane. Also,, the single plane is much lighter than the dual.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 11-07-2017, 12:56 PM
500plus's Avatar
Looks like after talking to Ken over here at East West, I will not be needing a 4BBL intake after all. I am going to install a draw through turbo setup on this little thing.
Thanks for the replies, Bill
