Old 11-15-2017, 01:25 PM
wreckmastr's Avatar
Default I'm looking for good quality side mirrors
I'm looking for good quality side mirrors. The ones I currently have will not stay they're just floppy as hell. and suggestions?
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
wreckmastr's Avatar
6.98 @ 199mph
4.53 @ 164mph
Old 11-15-2017, 01:48 PM
dataway's Avatar
dataway dataway is offline
Is there no way to get the glass out and tighten up the swivel ?
Old 11-15-2017, 02:00 PM
wbnapier wbnapier is offline
I have the same problem. All the reproduction side and rearview mirrors have the problem. If possible, try a small dab of blue loctite in the swivel. Otherwise, you will just have to rebuy them over and over.
Old 11-15-2017, 05:45 PM
dataway's Avatar
On the OEM mirrors I though it was possible to remove the mirror glass and there was an adjustable tension mechanism inside.
On the old bullet aftermarket mirrors there was often a screw in the end of the cone, attached to a tension spring, you'd tighten that screw to adjust it.
Seems like I've also seen them with a tension screw in the base, that you can see without removing the mirror.
Might also be able to move the mirror far out of place, take a center punch and dimple the ball a little bit ... but eventually that would probably wear out.
On that car you might need to weld them in place
Old 11-15-2017, 08:16 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Cool picture....
First I read the thread title, Then looked at the picture & thought
"well, there's your problem"
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 11-15-2017, 08:24 PM
wreckmastr's Avatar
I guess i'll try and epoxy / glue them some how.
6.98 @ 199mph
4.53 @ 164mph
Old 11-15-2017, 08:50 PM
68ragtop's Avatar
Or just slow down.
JK, I realize they shouldn't move that easily, just funny when you look at the force thats going on in the picture.
89 Trans am GTA
Old 11-15-2017, 09:16 PM
wreckmastr's Avatar
Originally Posted by 68ragtop View Post
Or just slow down.
LOL I know. At 194mph they all are hone move but these junkers wont even stay put in the garage.
6.98 @ 199mph
4.53 @ 164mph
Old 11-16-2017, 01:11 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I've been trying to figure this out for years along with many others, huge pain in the a$$.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 11-16-2017, 03:12 PM
dataway's Avatar
If they absolutely have to stay in the same place all the time ... yeah, epoxy or a bit of silicon bronze weld. Or maybe they can be drilled through with a small bit and pinned with a split pin.
Old 11-16-2017, 03:43 PM
rwarnerjr rwarnerjr is offline
These are great mirrors.
https://www.morrisclassic.com/collections/mirrors
Old 11-16-2017, 04:05 PM
wreckmastr's Avatar
PERFECT! Thank you
6.98 @ 199mph
4.53 @ 164mph
Old 11-16-2017, 06:09 PM
milkcrateracing's Avatar
milkcrateracing milkcrateracing is offline
I use red loctitie. fwiw
Don Hayden <[email protected]>
68 GTO, 70 Tempest Wagon, Two GMC's, a caddy & the FULMNTE
Old 11-16-2017, 10:27 PM
My two solutions; change to a remote mirror,
or take the regular mirror off the car, place it face down and carefully hammer a spike at 120 degree intervals where the swiveling part meets the ball. Does the trick!
Old 11-17-2017, 05:39 AM
dataway's Avatar
Shoot it with a small caliber rifle and it will be harder to move.
