Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-29-2018, 09:29 AM
leeklm's Avatar
leeklm leeklm is offline
Default Tanks, Inc. - 71-72 (73) GTO/LeMans
Like new Tanks Inc. fuel tank, pt. # TM34I-T - Includes new straps
Price w/o pump & float = $120 + shipping
Price with 225L/hr pump & float (no lines) = $230 + shipping
In case you have a 73 GTO/Lemans- this part number fits perfect!!
Old 07-31-2018, 12:08 PM
mchell's Avatar
mchell mchell is offline
Pm’d You
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 07-31-2018, 12:33 PM
leeklm's Avatar
Sorry- I am not able to reply to PM messages due to the Forum/Site issues currently going on. Will keep trying...
Old 07-31-2018, 01:15 PM
mchell's Avatar
I figured....looks like they are having some issues
I’m interested in your tank/pump for my 71 GTO.
did that setup work for you?....were you using it with a carb?.....noisy?......how old is it?
Old 07-31-2018, 01:58 PM
mchell's Avatar
Old 07-31-2018, 04:20 PM
cdrookie cdrookie is offline
I sent a PM wanting the LPW diff cover leeklm, do you still have it?
Old 07-31-2018, 06:30 PM
leeklm's Avatar
Hey Guys, yes, messages received. feel free to email me at [email protected] and we can square away the transactions.
Regarding the Tank... I love these units, and will likely be running one in the 68 firebird. They are baffled, work great for drag racing (at least it did for me), and the pump noise is barely noticeable. In fact, if your car makes any rumble at all, you will not hear the pump! Nothing like the typical Holley external race pump.
I ran mine with a RobbMC regulator feeding a holley and qjet. 3/8 steel line feed and return. I used it for about 3 years and maybe 5,000 miles at most.
Old 08-07-2018, 08:37 PM
leeklm's Avatar
Tank and pump still available. Complete with matching straps and filler neck.
Old 08-07-2018, 10:21 PM
The pump, what psi? And ohmage range for the float is 0-90Ω as per stock?
Old 08-08-2018, 10:28 AM
leeklm's Avatar
Pump is their GPA4, which is 255 ltr per hr, and about 80psi. Rated to support 630hp via fuel injection, or approx 700hp via carb.
I am pretty sure the sending unit uses the correct factory resistance, as it worked fine with my factory fuel guage.
Sent from my XT1585 using Tapatalk
Old 08-09-2018, 06:14 PM
excellent, thank you.
Old 08-14-2018, 06:41 PM
bobby326 bobby326 is offline
The frame is basically the same so i would think it would fit but would you know if this tank would fit a 67 Lemans.. I know the detentions are a little different.
Old 08-14-2018, 07:15 PM
leeklm's Avatar
Sorry I do not, I could provide a few pics and measurements so you can compare, or maybe can compare on tanks site.
Sometimes only the filler neck is different. If that is the case, you can cut your old filler neck off, and use the adapter hose and clamp to secure to the new Tank. This is actually the way they do it when supplying you with the new Tank and neck.
Old 08-14-2018, 08:59 PM
Thanks Tomorrow I’ll take the measurements and check to see if it will fit.
Old 08-14-2018, 09:01 PM
Where are you located/ shipping from
Old 08-14-2018, 09:59 PM
leeklm's Avatar
Mpls, MN. Quoted another guy about $60 to ship to FL, based on UPS calculator. Here are a few pics if it helps...
