Old 12-24-2018, 10:38 AM
Interceptor's Avatar
Interceptor Interceptor is offline
Default Are all Brake Master/Boosters Created Equal?
Looking for a replacement for my disc/drum 70 GTO. There are dozens of options on Ebay and elsewhere, 1-wire and 2-wire etc ranging from $115-300. Are they all created equal? I'll spend a little extra for the correct square master but not a fortune, and I'd rather have better-than-original operation than correct-appearing.
https://www.ebay.com/itm/68-72-gm-A-...oYSo:rk:1:pf:0
https://www.ebay.com/itm/Chevelle-Ca...cUT:rk:43:pf:0
What size bore would the original be?
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-24-2018, 04:23 PM
Schurkey Schurkey is offline
Huh? They're not electric.
That'll be in the service manual you should buy.
Old 12-24-2018, 06:12 PM
242177P's Avatar
242177P 242177P is offline
My 67 uses two 'wires' to keep the cover on. Just saying.
70 might use the square MC, so I dunno what's correct?
Old 12-24-2018, 06:16 PM
OG68 OG68 is offline
I think the correct terminology is Wire Bail or just Bail
Old 12-24-2018, 07:48 PM
That's it
Sent from my SM-G930W8 using Tapatalk
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-25-2018, 09:53 PM
64speed's Avatar
64speed 64speed is offline
Some people will flame me for promoting chinese junk but I have had good luck with CPP. I have used them on three cars. Never any installation issues and the one problem I had a new one was overnighted from California. They also have lifetime warranty to original owner.
Old 12-26-2018, 10:21 AM
I've had very good results with Pirate Jack over the years, boosters these days are a high fail-rate item.
https://piratejack.net/1964-1972-gm-...its/disc-drum/
Pretty sure OE for a Disc/Drum setup is 1 1/16 bore, but you can adjust for desired pedal feel.
If you're replacing both, you can consider going to a smaller booster, if you're not concerned with originallity. A 9" dual diaphram is a nice upgrade, gives room for tall valve covers, and a little extra boost, especially in lower vacuum situations.
If you run headers, and you did a make-shift relocation of the combo valve, order with a new valve and bracket, and the front line conversion kit. That will clean it up very nicely. You get a union, and a short length for the rear line, so you don't have to replace the whole rear line.
Old 12-26-2018, 12:36 PM
Good info, thanks.
Is there any advantage to the Corvette design over the square design?
How can the cast-iron MC be kept looking new?
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 12-26-2018, 12:57 PM
The vette ones are 'generic', and there usually isn't any cup/pin depth issues.
You can spray/coat the body with a coating of choice to prevent corrosion. You can wipe it down with acetone and spray it with as-cast engine paint, works pretty good.
Old 12-26-2018, 12:59 PM
Eastwood Brake Grey is a good choice too, using their' prep recommendations:
https://www.eastwood.com/eastwood-br...y-aerosol.html
Old 12-30-2018, 12:29 AM
NeighborsComplaint's Avatar
I installed a 9" dual diaphragm booster with the corvette style master cylinder. The only issue I have with this setup is the extreme angle it places the booster at reduces the fluid volume since the reservoirs are half empty because of the angle. Come spring, I am going to replace the angle brackets (OEM style for 11" dia booster) with straight brackets.
Old 12-30-2018, 09:47 AM
My projects always get the G-Body Aluminum Master Cyls for best results, even 4-wheel disc.
Old 12-30-2018, 12:09 PM
Whatever angle the master cylinder is set at, needs to provide a straight pushrod angle to the brake pedal.
Master cylinders are typically tipped "up" in front to make a straighter pushrod angle to the pedal. Don't screw up that geometry just to gain some fluid capacity.
Old 01-03-2019, 12:54 AM
242177P's Avatar
I agree with this, kinda. Needs further elaboration. Power masters are typically tipped up. Pushrod position on the pedal arm affects piston travel *and* leverage. Manual was level... used the higher hole. Power was angled, used the lower. At least as far as the A-bodies I'm familiar with.
But yeah, bad geometry is a no-no. If you're going to level it, you gotta know what youre doing.
Old 01-03-2019, 08:26 PM
So is running around with the front reservoir cover clamp disengaged because it rubs on the underside of the hood and a spongy pedal from pumping air into the brake system when braking after hard acceleration because the port in the bottom of the reservoir is momentarily uncovered.
Old 01-03-2019, 09:12 PM
Keith Seymore's Avatar
1). Jack the back of the car up
2). Top off the master cylinder
3). Enjoy
'63 LeMans Convertible
'63 Grand Prix
Old 01-05-2019, 06:30 PM
3). Enjoy mopping up the spilled brake fluid from the overflowing reservoirs
There, fixed it for you.
Old 01-06-2019, 12:44 PM
Put air shocks on it and pump them up! Heheh!
Old 01-12-2019, 01:09 AM
What's wrong with the makeshift conversion? And is there a good reason to go with a new attached prop valve? Besides the enjoyment of redoing all the lines instead of just swapping masters …
PJ website has no pics of that kit to see what's in it. Sorry the car is in storage so I can't recall exactly what the whole setup looks like.
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 01-12-2019, 09:08 AM
64speed's Avatar
This is where CPP shines. The prop valve is attached to the master and they give you a fitting to plug into your old junction block and splice into your rear brake line
