Old 06-12-2019, 08:22 PM
grd777 grd777 is offline
Default help starter problem on my 75 t/a
i am more of a ford guy , but it seems my car wont start sometimes , it happen today so i pushed it and kick started IT (4 speed car). I DID REPLACE THE STARTER LAST YEAR . IS IT A BAD GROUND AND WERE DOES THE STARTER WIRE GO TO FROM THE STARTER
Old 06-14-2019, 06:27 PM
i think it could be a heat soak issue how do i check i have headers thta touch the starter
Old 06-14-2019, 06:39 PM
Lee's Avatar
Lee Lee is offline
Look into getting a mini-starter. It will have more clearance from the headers, as well as more powerful.
LOTS of discussions on here, do a search and you'll find a lot of info. RobMC, IMI, CSR, several brands to choose from. Avoid the Jegs/Summit starters, they don't tend to be as reliable. SecondGenGraveyard on Facebook has some good prices on some.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 06-14-2019, 09:41 PM
form74's Avatar
form74 form74 is offline
I bought the one from RamAir , no issues over 10 years
https://www.ramairrestoration.com/ms...and-later.html
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 06-24-2019, 11:51 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Had the same issue years ago, intermittent start problem on 76 manual TA .
Turns out the back drive rod was missing sometimes allowing the lever on the column to slip down and act as an inhibitor
Solution - Cable tie it in the UP position and never have the issue again - Worthwhile checking
ID:	514778   Click image for larger version
Working on going faster (and now staying dry at the same time !!)
Old 06-25-2019, 09:00 AM
TAKerry TAKerry is offline
Could be this, especially if you have headers as the backdrive wont work with them in place. If that is the problem, a simple wiggle to the collar on the column should fix that. More likely heat soak though, if it 'fixes itself' with a bit of a cool down. I had the same problem with the stock starter (along with most everyone else). I tried the insulator blanket first and it did nothing. I put in a mini starter and have not had a problem since. I got mine from Summit and hate to read they have problems, so know I guess I have that to worry about!
