Old 05-11-2020, 07:04 PM
CarlBraun's Avatar
CarlBraun CarlBraun is offline
Default 1970 Ram Air IV Judge motor sittin' in the dirt
eBay ad for a 1970 ram Air IV motor sitting in the dirt in North Carolina. the ad says it has 614 heads and may even come with a 10 bolt rear end and transmission.
someone go check this out....https://www.ebay.com/itm/Limited-Edi...MAAOSwiuVeZtXZ
1970 Judge Ram Air IV Polar White Auto
Old 05-11-2020, 07:07 PM
CarlBraun's Avatar
Default RA IV motor in the dirt
here is the photo showing the motor and aluminum intake
Name:	1970 Ram AIr IV engine in the dirt.jpg
Old 05-11-2020, 07:10 PM
Brewster's Avatar
Brewster Brewster is offline
Wonder what the block is??
Old 05-11-2020, 08:59 PM
FASTASSBIRD FASTASSBIRD is offline
Intake is aftermarket. Single plane plenum. I see nothing to suggest it’s a IV. if it is it’s probably for an auto as I see a flex plate on the back
Old 05-11-2020, 09:13 PM
Default Great way to store an engine!
8 bolt water pump & timing cover, as well
Old 05-12-2020, 02:50 AM
No pics of any identifying markings. No telling what it really is. I noticed that water pump also. Seems like every Pontiac engine 'came out of a Judge'....or at least a GTO.
If the 614 number is correct though...might be worth a look just for those.
Old 05-12-2020, 07:00 AM
johnta1 johnta1 is online now
One pic does show it has at least one round port head.
Old 05-12-2020, 01:34 PM
Region Warrior's Avatar
Either been there for years or very soft ground. Gona need a back hoe lol.
Old 05-12-2020, 01:47 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Why is the photo of the side of the engine effectively cropped to omit the view of the cylinder head's exhaust area?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 05-12-2020, 02:54 PM
68bird400HO's Avatar
Seller has zero feedback.
Old 05-12-2020, 03:17 PM
1969 Ram Air 1969 Ram Air is offline
The seller couldn't pull the motor out of the quick sand? Sheesh.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 05-12-2020, 04:52 PM
RAIV55 RAIV55 is offline
I would say the odds are really against the bidder on this.
Do you think it would really turn over?
The heads would likely be the only thing of interest. What are the chances of the heads being better than powdered rust?
For $2500 you'd be better off buying lottery tickets
Monty Frerichs
B&M Machine
Box Elder SD
Old 05-13-2020, 12:30 AM
piss poor advertising and pics
but not as bad as the storage method .
The clear plastic sheet covering deteriorated years ago
Old 05-13-2020, 10:03 AM
Mcronk Mcronk is offline
Appears to have had a Moroso Vacu Pan system on it. Also has poly locks on rocker studs. Probably was someone's drag/bracket motor back in day. Normally would not install that system on a street car with mufflers. Also looks like an old Mallory Unilite distributor.
