73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 03-07-2021, 04:58 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Driveshaft removal
Trying to get the drive shaft removed from my 77 lemans any thoughts besides the back bolts
Sent from my SM-S111DL using Tapatalk
Old 03-07-2021, 08:32 PM
694.1 694.1 is offline
Have you run into difficulty? This is normally pretty easy stuff. Did you try giving it a little smack forward? They can hang up in the yoke...
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-07-2021, 08:34 PM
tom s tom s is offline
Have a old yoke handy to put in the trans when you pull the shaft!Or drain it first.Tom
Old 03-07-2021, 09:12 PM
1969GiPper 1969GiPper is offline
[QUOTE=Flashflood;6231748]Trying to get the drive shaft removed from my 77 lemans any thoughts besides the back bolts
Sent from my SM-S111DL using Tapatalk[/QUOTE
Are you using a hoist or is the vehicle on the ground? If on the ground make sure you’ve blocked the wheels and have set the parking brake so that the vehicle can’t roll away when the driveshaft is out. Once the shaft is out having the transmission in park (or In gear on a manual trans) does nothing to stop the vehicle from rolling away. Safety first.
The Following User Says Thank You to 1969GiPper For This Useful Post:
Old 03-08-2021, 12:42 PM
Got it was a little cab on the u joint next stop removing engine parts
Old 03-08-2021, 02:02 PM
Generally recommended to mark it so you can put it back in in the same position.
