Old 05-03-2021, 09:37 PM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
Default 1964-1965 GTO pinion seal details needed
So factory part number is 9773216. I am getting ready to help replace the pinion seal on both a 64 and 65 GTO. The owner of the 65 says a shop tried to replace the seal twice and twice they had the wrong seal. Not sure where the shop sourced the seal. To make sure we get the correct seal, does someone have the inner and outer diameter specification on the seal? The last one I purchased was for my 70 GTO from an industrial supply source.
1970 GTO
Originally 400, M20, Atoll Blue, PS, PDB, A/C
Now has 461 stroke, Keisler RS600 5 speed.
Just a fun driver
Old 05-03-2021, 09:58 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
SKF says that their SKF 16500 seal is a match for 9773216. Here are the specs: https://www.rockauto.com/en/moreinfo...842786&jsn=873
Old 05-03-2021, 10:02 PM
bdk1976 bdk1976 is offline
I would measure your part and fit the seal to that. If the standard ones aren't fitting, perhaps it was machined at some point or maybe it's a different type of axle than you ordered the part for or ?
Old 05-03-2021, 10:05 PM
... and here is the page from the 1966 MPC stating that seal # 9773216 is 1 5/8" ID and 2 21/32" OD.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 05-03-2021, 10:10 PM
Bill, thank you. bdk1976, I will double check when I have access.
1970 GTO
Just a fun driver
Old 05-04-2021, 12:32 AM
Note that the MPC calls out your 9773216 seal AND another, different size seal 9784286 also used on some 64-65 Tempests (and GTOs) as well as full size 66 Pontiacs. That crosses to SKF 19273. Specs here: https://www.rockauto.com/en/moreinfo...835254&jsn=265
Maybe this seal is needed????
Old 05-04-2021, 07:04 AM
Cardo's Avatar
Cardo Cardo is offline
They're cheap enough, order both to have on hand. One of the two has got to fit unless something else is going on as mentioned above,
The Following User Says Thank You to Cardo For This Useful Post:
Old 05-04-2021, 11:26 AM
This thread may be of help, particularly the Youtube link in post # 10
https://forums.maxperformanceinc.com...d.php?t=849610
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
The Following User Says Thank You to Singleton For This Useful Post:
Old 05-04-2021, 02:30 PM
Kenth's Avatar
Kenth Kenth is offline
This is used for the 1964-65 Buick style 8.2" rear end:
https://www.rockauto.com/en/moreinfo...350492&jsn=411
And this is used for 1964-72 Pontiac style 8.2" and 1966-70 fullsize rear end:
https://www.rockauto.com/en/moreinfo...350492&jsn=409
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-04-2021, 02:36 PM
GeeTeeOhh's Avatar
GeeTeeOhh GeeTeeOhh is offline
Just went thu this myself. there are two different sized pinion yokes for 64-65. I ordered the SKF 16500 for my 65 rear end (1-5/8" bore) , which has the following specs:
Width (IN) 0.4
Shaft (IN) 1.645
Bore (IN) 2.656
Outer Diameter (IN) 2.66
Boretite Y
Alternate/OEM Part Number(s): 1199566, 1231562, 1362360, 1362857, 1387449, 9773216, 9774408, 9774409.
The other size pinion yoke seal i have seen listed for 64-72 GTOs is a SKF 19273 (1-7/8" bore)
Width (IN) 0.5
Shaft (IN) 1.938
Bore (IN) 2.762
Outer Diameter (IN) 2.766
Boretite Y
Alternate/OEM Part Number(s): 1236323, 1236324, 1236325, 1242066, 1242067, 1242068, 1243465, 1243466, 1243468, 1496123, 26033578, 3633518, 396470, 404294, 404795, 9784286, 9784508, 9787384, 9793675, 9793685
The Following User Says Thank You to GeeTeeOhh For This Useful Post:
