Old 06-01-2022, 04:44 PM
ekancler ekancler is offline
Default W72 T/A Cam - 1977 vs 1978/79
I've been wondering why Pontiac used a different cam in the 1977 W72 T/A than the 1978/79 W72s.
The differences in specs are modest but meaningful, with the 1978/79 cam being slightly more aggressive:
Cam, AID, AED, ID@050, ED@050, IL1.5, EL1.5, LSA, OL, CL
1977 549112, 274, 298, 190, 213, 0.365, 0.41, 114.5, 55, 116
1978/79 10003402, 273, 289, 200, 213, 0.41, 0.41, 113, 54, 118
Did Pontiac undershoot for 1977 on purpose? Emissions standards certainly didn't get less stringent in 1978 yet they went to a more aggressive cam. It would seem they left power on the table in 1977.
Curious if anyone knows the history or rationale there. And also why they didn't go with the 067.
Old 06-01-2022, 05:16 PM
Stan Weiss's Avatar
Where did you get those specs from?
This article by Rocky shows different specs.
Cam Quandary
An In-Depth Look at the '77-'79 T/A 6.6 Camshaft Specs
https://www.motortrend.com/how-to/hp...-cam-quandary/
You could also look at this thread
W72 cam vs. Pontiac 068 cam?
https://forums.maxperformanceinc.com...d.php?t=386047
Stan
Pontiac Pump Gas List
Old 06-01-2022, 05:24 PM
25stevem's Avatar
25stevem 25stevem is offline
I don’t think anyone really knows why looking back on it today, but my guess is this.
Pontiac new in 77 that the 78 400 would be the last Pontiac V8 other then the 301 with a resemblance to a classic Pontiac motor.
They also really still wanted to stick it to Chevy since there motor would carry on in the GM, and Pontiac was likely pissed about that!
The extra effort put into the Cam change for the TA motors really made the 78 and 79 Z28 look like Grandma’s motor with its meager 185 hp rating as compared to the TAs 220.
Old 06-01-2022, 05:52 PM
Cam Quandary
Stan
Honestly everywhere I look the specs are slightly different. The specs I posted are very close but not identical to the specs in the back of Rocky's book.
Old 06-01-2022, 06:34 PM
That sounds like it makes sense to me. That said, I wonder if they knew they were leaving power on the table with the 77 W72.
Old 06-01-2022, 07:20 PM
Jay S's Avatar
Jay S Jay S is offline
The single cat on the 77 cars might have been part of the reason for a different cam for the 78-79 w72s, IRC, the later w72s in 78 had dual cats.
Old 06-01-2022, 08:01 PM
78-79 still had single cat but had dual mufflers vs single crossflow.
The Following 4 Users Say Thank You to Skip Fix For This Useful Post:
Old 06-01-2022, 08:21 PM
Jay S's Avatar
Thanks Skip. I had forgot it was just the dual mufflers versus the cross flow. I was think it was suppose to be an improvement over 77s.
Old 06-01-2022, 10:07 PM
77 TRASHCAN's Avatar
That large Cat was supposedly a high flowing unit ( for its time). I installed a test pipe on my car. Saw no increase in performance or MPG’s, that I could tell. I still have my old converter.
Shut it off
Shut it off
The Following 2 Users Say Thank You to 77 TRASHCAN For This Useful Post:
Old 06-02-2022, 12:08 AM
Are you saying that you bypassed the cat with no discernible power increase?
Old 06-02-2022, 07:22 AM
Yes...
Shut it off
Shut it off
Old 06-02-2022, 09:25 AM
Jay S's Avatar
I don’t know if all those late 400s had the same cat? I assume all the 77 400s used the same cat?. The cam in the 180 HP may have been small enough that the big cat didn’t hurt it much. My brother removed the factory cat on his 76 180 HP corvette and it made a notable difference, but I bet it had a smaller cat that what Pontiac used on these engines.
My 77 4 speed with 3.23s had the factory type single transverse to dual system on it and someone previously removed the cat. Comparatively a friend had a 78 w-72 that was completely stock but had 3 tube headers and 3.42s. My 77 seemed like it was stronger on mid range, no question his 78 had more charge on the top.. For the most part I think the biggest thing that made the 78s quicker was the 3.42 gear offering, followed by the cam, then the exhaust changes. The nose on the 79 cars really slip thru the air, those 79 4 speed W72s in 79 are likely the quickest of all of the W72s. I recall on 79 road test back in the day clocked the top speed at a little over 130, and they mentioned that the top speed RPMs were well past the 5K redline on the tach. Pretty sure my 77 4 speed engine would have done before that if it with it’s cam, and it’s top speed in 77 was just over 120. I never took mine past 5000 rpm. I typically stopped at 4600, could tell it was done before 5K.
Old 06-02-2022, 10:29 AM
78 180 HP had the single muffler only the W72 220HP got the duals. I missed getting the W 72 by 1 month when I got mine.
Old 06-02-2022, 07:37 PM
jerry455 jerry455 is offline
I bought a 20,000 mile, used W72 Gold 1978 T/A in the spring of 1982. I removed the cat, richened the carb, quickened the ignition curve and opened the scoop. It made a world of difference. I was beating a lot of my friends "faster cars". They were surprised that my T/A ran that well. It ran really strong. Most people used to laugh at the T/As, calling them the disco cars. I stopped a lot of those comments when I beat their cars.
Old 06-02-2022, 09:30 PM
PAUL K's Avatar
PAUL K PAUL K is online now
78 TA 6.6 cars were quick. Do the mods Jerry455 mentioned and you were running mid fourteens. That is what the 5.0 Mustangs ran with a good driver years later.
Go fast, see Elvis!
Old 06-02-2022, 09:37 PM
Yes...
I read in a couple of magazines, that the TA's got the same Cat as the Corvette. Maybe it wasn't high flowing. Seemed like all Cats looked like those, back then I do believe that the inlet on the Cat was bigger than the outlet. The outlet dumped into a 2-1/4" pipe on a stock 180 HP TA exhaust (the transverse muffler). I'm an expert at nothing. Just repeating what I read...there was fake news back then....too...
Shut it off
Shut it off
Old 06-02-2022, 09:50 PM
72projectbird's Avatar
Can confirm that a 78 Corvette has the same cat as a 77-78 Trans Am. I took a test pipe I had from a 78 Vette and installed it on a 77 TA. Direct fit. Cats look identical.
Both were slow as chit. Fixed the Vette by building a 6.0 LS for it, and kicked the TA down the line.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 06-03-2022, 10:03 AM
My 78 180 HP and the 2.56s ran high 14s-barely in 3rd.
Old 06-03-2022, 04:13 PM
Jay S's Avatar
I want to know details now Skip. That is blistering fast for a base L78 with 2.56s. That is awesome..
Old 06-03-2022, 04:17 PM
The old DIckinson track that the Gays used to race at.
