Old 06-24-2022, 11:38 PM
ErikW's Avatar
ErikW ErikW is offline
What did you pay for your Turbos?
Hope you have enough cash to purchase another set.
I did the air scoops "down low", (copying the Olds 442 1966 & 1967 Ram Air cars, but I had the air feeding a circular Ram Air "Box".
https://www.ramairbox.com/ The air cleaner had a filter.
I was amazed with how much road trash the scoops collected and transferred to the Air Box. A cup-full at times.
In your case I see no filtering system prior to the Turbocharger compressor blades.
Maybe you have some screening that was not visible in the pictures.
Hate to see a new set of Turbos trashed and needing a rebuild minimum because you killed your turbos.
Big Chief got his turbos for free from Precision Turbos (so if the Oklahoma grit kills them) he can get another set.
Food for thought.
Unfortunately, air filters are super restrictive on the front of turbos, but we do have screens to keep out low flying birds and some debris. Also at 750.00 ea. Its not too hurtful to replace one. Don't have Big Chief money or sponsors.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #282
Old 06-25-2022, 12:53 AM
R 70 Judge's Avatar
Thanks for the turbo info. Your car is so bad ass!!
James
1970 Trans Am
  #283
Old 06-25-2022, 08:32 AM
Screens are a lot better vs nothing.
At 750 per turbo, who did you buy your turbos from?
I already have my stuff so the question relates to the manufacturer.
  #284
Old 06-25-2022, 04:12 PM
73 TRANSAM 73 TRANSAM is offline
Tom,
He bought it from VS racing.
  #285
Old 06-25-2022, 05:46 PM
If you are not planning on running boost above 18 psi, most of the decent Chinese
offerings will do the job with either a sleeve bearing supporting the compressor/turbine shaft or sometimes there will be a ball bearing option that is not too expensive.
Key is the boost pressure/load exerted on the compressor/turbine shaft.
I looked at the website. The people are a Marketing outfit. Not a Turbo Manufacturer
like Borg Warner or Garrett. But they still might have access to some good parts.
Richard Holdener has lots of videos on different turbos he has tested over the years.
And he and his wife are very nice people. https://www.youtube.com/channel/UC8u...63l1-uRSx6XbnQ
I am disappointed though that no one in the pontiac world was willing to loan him a 57-58 Pontiac flywheel so he could run a older Pontiac engine with a turbo on it.
  #286
Old 07-01-2022, 04:02 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I might need a poster of this car when its done. The paint and graphics, like everything else, look fantastic!
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
  #287
Old 07-06-2022, 09:28 PM
ErikW's Avatar
https://youtube.com/shorts/8KKmN9Z-_Ac?feature=shareIt's Alive!
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
  #288
Old 07-06-2022, 10:09 PM
Thats a very nice looking TA you have there. Are you going to be at Norwalk?
  #289
Old 07-06-2022, 10:49 PM
R 70 Judge's Avatar
It’s alive!!
James
1970 Trans Am
  #290
Old 07-07-2022, 04:44 PM
ErikW's Avatar
Yes, we'll be there
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #291
Old 07-17-2022, 08:13 AM
ErikW's Avatar
Bought a Cricut machine and added some custom touches to the graphics. Attended a track rental on 7/14 and just worked on the 60ft times. We managed to get her from an initial 1.32 down to a 1.18 before we got rained out for the day. Previous best has been 1.26 at Norwalk during Drag Week 2021. Looking for low teens or high 0's. Between lauch boost, tire pressure and shock settings we are closing in.
ID:	594467   Click image for larger version
ID:	594468   Click image for larger version
ID:	594469   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #292
Old 08-16-2022, 09:13 PM
Nice talking with you guys at Norwalk last Saturday. I'm the one who asked about your custom trans pick up assembly. Good luck with your quest for a low 8's in ur car.
The Following User Says Thank You to 73 TRANSAM For This Useful Post:
  #293
Old 08-18-2022, 01:02 AM
R 70 Judge's Avatar
Erik, I’m hoping you’ll share some information.
Are you running the 4” or 6” clear view oil filter? It’s hard to tell from the picture I saw. Did you go with the -12 lines? Screw on filter? Are your turbos directly fed from the cnc housing?
I’m planning on adding one in preparation for the turbo upgrade.
https://seethroughfilter.com/filter-nav-page/
James
1970 Trans Am
  #294
Old 08-18-2022, 06:30 AM
Those see thru filters look like they use Oberg filter elements...
  #295
Old 08-18-2022, 09:00 PM
ErikW's Avatar
4" with spin on filter. -10 lines. Turbos are fed from the oil port next to the distributor.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #296
Old 08-18-2022, 09:02 PM
ErikW's Avatar
Thank you. Nice to meet you as well.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #297
Old 11-24-2022, 03:21 PM
R 70 Judge's Avatar
Erik, what are you using for your Hall effect signals for the crank sensor and cam sensor? A crank trigger? I plan on using the Holley dual sync. Just checking if I need to modify my plan. Thanks
James
1970 Trans Am
  #298
Old 11-24-2022, 09:33 PM
ErikW's Avatar
We use a 36-1 crank trigger wheel and sensor from Holley and a Luhn Performance cam sync. We custom made the crank sensor bracket.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #299
Old 11-24-2022, 10:46 PM
Some very nice package work for the basic turbo mounts, inter-cooler plumbing, etc.
  #300
Old 11-29-2022, 12:24 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Erik,
How do you like the adjustable front spring pockets? I have some from Innovative Racecraft for first Gen and I’m going to install them when I do my floors and frame rail replacement. Did you plug the remaining holes with plastic hole plugs to keep smoke out of the car from Burnouts? Does the caltracs fit in the upper most portion of the bracket?
69 Firebird - Angry Bird
455 with 84mm Torqstorm
