#281
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT |
#282
Thanks for the turbo info. Your car is so bad ass!!
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#283
At 750 per turbo, who did you buy your turbos from? I already have my stuff so the question relates to the manufacturer. Tom V.
#284
Tom,
He bought it from VS racing. |
#285
If you are not planning on running boost above 18 psi, most of the decent Chinese
offerings will do the job with either a sleeve bearing supporting the compressor/turbine shaft or sometimes there will be a ball bearing option that is not too expensive. Key is the boost pressure/load exerted on the compressor/turbine shaft. I looked at the website. The people are a Marketing outfit. Not a Turbo Manufacturer like Borg Warner or Garrett. But they still might have access to some good parts. Richard Holdener has lots of videos on different turbos he has tested over the years. And he and his wife are very nice people. https://www.youtube.com/channel/UC8u...63l1-uRSx6XbnQ Tom V. I am disappointed though that no one in the pontiac world was willing to loan him a 57-58 Pontiac flywheel so he could run a older Pontiac engine with a turbo on it.
#286
I might need a poster of this car when its done. The paint and graphics, like everything else, look fantastic!
. Mark S . Who needs nice and pretty, when you can have mean and nasty? KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs . So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine! >>My 73 Build thread |
#287
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT Last edited by ErikW; 07-06-2022 at 09:34 PM. |
| The Following User Says Thank You to ErikW For This Useful Post: | ||
#288
Thats a very nice looking TA you have there. Are you going to be at Norwalk?
#289
#290
Yes, we'll be there
#291
Bought a Cricut machine and added some custom touches to the graphics. Attended a track rental on 7/14 and just worked on the 60ft times. We managed to get her from an initial 1.32 down to a 1.18 before we got rained out for the day. Previous best has been 1.26 at Norwalk during Drag Week 2021. Looking for low teens or high 0's. Between lauch boost, tire pressure and shock settings we are closing in.
#292
Nice talking with you guys at Norwalk last Saturday. I'm the one who asked about your custom trans pick up assembly. Good luck with your quest for a low 8's in ur car.
| The Following User Says Thank You to 73 TRANSAM For This Useful Post: | ||
#293
Erik, I’m hoping you’ll share some information.
Are you running the 4” or 6” clear view oil filter? It’s hard to tell from the picture I saw. Did you go with the -12 lines? Screw on filter? Are your turbos directly fed from the cnc housing? I’m planning on adding one in preparation for the turbo upgrade. https://seethroughfilter.com/filter-nav-page/
#294
Those see thru filters look like they use Oberg filter elements...
#295
4" with spin on filter. -10 lines. Turbos are fed from the oil port next to the distributor.
#296
Thank you. Nice to meet you as well.
#297
Erik, what are you using for your Hall effect signals for the crank sensor and cam sensor? A crank trigger? I plan on using the Holley dual sync. Just checking if I need to modify my plan. Thanks
#298
We use a 36-1 crank trigger wheel and sensor from Holley and a Luhn Performance cam sync. We custom made the crank sensor bracket.
#299
Some very nice package work for the basic turbo mounts, inter-cooler plumbing, etc.
#300
Erik,
How do you like the adjustable front spring pockets? I have some from Innovative Racecraft for first Gen and I’m going to install them when I do my floors and frame rail replacement. Did you plug the remaining holes with plastic hole plugs to keep smoke out of the car from Burnouts? Does the caltracs fit in the upper most portion of the bracket? Sent from my iPhone using Tapatalk
69 Firebird - Angry Bird 455 with 84mm Torqstorm |
