Old 08-08-2022, 09:29 AM
pontiac rodder's Avatar
pontiac rodder pontiac rodder is offline
Default 1963 lemans
For sale 30 K, Located in Wisconsin
IAII block 498 cu in
325 cfm Kauffman Heads
1.5 rocker arms
Comp cam hydraulic roller Howards hydraulic roller lifters
Northwind intake
Holley sniper X-Flow EFI
Hyper spark ignition
Holley distributor
16 volt battery and alternator
Ram air exhaust 2.5 in manifolds
Pypes exhaust pipes and mufflers and stainless steel to the rear.
Turbo 400 trans reverse valve body with JW bellhousing
Precision of Hampton 3300 stall convertor
B&M ratchet shifter
Strange 4 wheel disc brakes
Strange Ford 9" housing
Moser Wave track center section with 350 gear
35 spline axles with 5/8 studs
12 gal fuel cell
15x9 billet specialty's street lites in rear with M&H drag radial
15x4 billet specialty's street lites in front with M&H (DOT) front runners
Factory interior with power windows and removable steering wheel
850 cert cage (expired but should re-cert )
Stock front suspension with Calvert shocks
Chassis engineering ladder bar, with anti roll and wish bone
QA1 coil overs
Heim joints with shoulder bolts .
All steel car from Arizona in the late 80's
Orion sliver is the color
Possibly going to Norwalk 414 313 7860 Peter D.
ID:	596048   Click image for larger version
ID:	596049   Click image for larger version
Old 08-08-2022, 09:56 AM
more pictures
ID:	596051   Click image for larger version
ID:	596052   Click image for larger version
Old 08-08-2022, 10:44 AM
78w72 78w72 is offline
BAD A$$ !!
Old 08-08-2022, 10:52 AM
Tim john Tim john is offline
Agreed
Tim john---
Old 08-08-2022, 01:29 PM
for those who have asked cam card
The Following User Says Thank You to pontiac rodder For This Useful Post:
Old 08-08-2022, 01:42 PM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
Very nice! You should have no problem selling this. Good luck with the sale.
Old 08-09-2022, 02:12 PM
Sold Thanks PY
