Old 03-07-2023, 09:18 PM
64speed's Avatar
64speed 64speed is offline
Originally Posted by Gach View Post
Great ! What did you end up using for rocker arms. Hopefully not the BBC ones. ?
The BBC Chevy ones made the best valve pattern. Setup with Butlers recommended pushrods. I got the crower stainless steel
  #1482
Old 03-07-2023, 10:32 PM
Gach's Avatar
Gach Gach is offline
Not understanding so which ones did you use. Crower or BBC ones. Thanks
Old 03-07-2023, 11:48 PM
64speed's Avatar
Crower stainless but for a BBC
  #1484
Old 03-08-2023, 12:41 AM
Gach's Avatar
Gotcha
Old 03-08-2023, 08:56 AM
Butler recommended the BBC rockers?
  #1486
Old 03-08-2023, 09:33 AM
64speed's Avatar
No they provided the pushrod length necessary. I was overloaded with information I didn’t understand yesterday but basically this is my 2nd go round with this. My Pontiac rockers just never made the grade with these heads but the BBC make the grade perfectly
  #1487
Old 03-08-2023, 11:13 AM
So you gave Butler the length your builder provided and they shipped you the pushrods requested.
You should ask them about using BBC rockers, see what they say.
Bookmark this thread for future reference.
  #1488
Old 03-08-2023, 03:51 PM
NeighborsComplaint's Avatar
Already called it after the first motor broke. It's the rockers.
Interesting tidbit ... assume for the moment the OP was running the Lunati 712 cam in the ill-fated motor. With 1.7 ratio rockers his lifts were .606"/.623" (I/E). If the rockers were 1.8 ratio, .642"/.660" (I/E). If the cam was the 713 , then .634"/.640" (I/E) w. 1.7 rockers and .671".678" (I/E) w. 1.8 rockers.
Triple Black 1971 GTO
  #1489
Old 03-08-2023, 03:58 PM
grivera's Avatar
grivera grivera is offline
Dave - did the builder have Pontic Crower SS on hand as well or just the BB SS Crowers?
Will Rivera
  #1490
Old 03-08-2023, 04:11 PM
64speed's Avatar
Yes he had a few different brands. Caster1 had the same problem with his engine
  #1491
Old 03-08-2023, 06:43 PM
Gach's Avatar
The only thing that I can think of there’s a distinct possibility The stud placement on those heads are a little off compared to standard placement. Enough so the BBC rocker work perfectly.
I’ve kind of run into this situation before.
The Following 2 Users Say Thank You to Gach For This Useful Post:
  #1492
Old 03-08-2023, 09:07 PM
64speed's Avatar
They work and I have good geometry, no problems on the test stand
  #1493
Old 03-08-2023, 09:12 PM
Gach's Avatar
I believe it, and don’t think it had anything to do with the original failure. Like I said I’ve run into this situation before.
The Following User Says Thank You to Gach For This Useful Post:
  #1494
Old 03-08-2023, 09:43 PM
64speed's Avatar
Wayne said that it had happened on mine and Tommys engage but obviously he had never experienced it with factory parts.
  #1495
Old 03-12-2023, 05:34 PM
1968GTO421's Avatar
Good point, however I believe this time 64speed is using the 041 cam with .470" lift (with 1.5 rockers). With 1.7 rockers lift would be around .533". Many cams have that lift with 1.5 rockers so I think this time he might be OK with those rockers. But I would not go that route. I would investigate the problem Gach mentions in post #1491. I believe Pontiac engineeers knew the limits of their block and didn't exceed the 1.65 ratio rockers. FWIW
GTOAA--https://www.gtoaa.org/
  #1496
Old 03-12-2023, 08:24 PM
tom s tom s is offline
FYI,in 1963 pontiac offered 1.75 rockers for it 421 SD heads!I have a half set of NOS ones.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #1497
Old 03-12-2023, 10:42 PM
Gach's Avatar
If the geometry is correct, lift not going to matter. As long as the duration doesn’t exceed 200 at .200 lift thats when the issue manifests itself. I doubt his hydraulic roller was.
Here’s what I did fine to be a issue, I’ve found 2 blocks that the lifter bores had hair line crack. Remember certain lifter bore are attached to the block like a cup handle. 2 and #6. I think #2 let go on his block.
  #1498
Old 03-13-2023, 04:16 AM
64speed's Avatar
Yes it was #2
  #1499
Old 03-15-2023, 04:16 AM
64speed's Avatar
Back on the road. For some reason the hydroboost seems a little spongier than it was before but maybe it’s just my mind playing tricks on me
  #1500
Old 03-15-2023, 08:25 AM
400 Lemans's Avatar
Good job.
