#1481
The BBC Chevy ones made the best valve pattern. Setup with Butlers recommended pushrods. I got the crower stainless steel
#1482
Not understanding so which ones did you use. Crower or BBC ones. Thanks
Crower stainless but for a BBC
#1484
Gotcha
Butler recommended the BBC rockers?
#1486
No they provided the pushrod length necessary. I was overloaded with information I didn’t understand yesterday but basically this is my 2nd go round with this. My Pontiac rockers just never made the grade with these heads but the BBC make the grade perfectly
#1487
You should ask them about using BBC rockers, see what they say. Bookmark this thread for future reference. .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#1488
Already called it after the first motor broke. It's the rockers. Interesting tidbit ... assume for the moment the OP was running the Lunati 712 cam in the ill-fated motor. With 1.7 ratio rockers his lifts were .606"/.623" (I/E). If the rockers were 1.8 ratio, .642"/.660" (I/E). If the cam was the 713 , then .634"/.640" (I/E) w. 1.7 rockers and .671".678" (I/E) w. 1.8 rockers.
Triple Black 1971 GTO Last edited by NeighborsComplaint; 03-08-2023 at 04:26 PM. |
| The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
#1489
Dave - did the builder have Pontic Crower SS on hand as well or just the BB SS Crowers?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#1490
Yes he had a few different brands. Caster1 had the same problem with his engine
#1491
The only thing that I can think of there’s a distinct possibility The stud placement on those heads are a little off compared to standard placement. Enough so the BBC rocker work perfectly.
I’ve kind of run into this situation before.
| The Following 2 Users Say Thank You to Gach For This Useful Post: | ||
#1492
They work and I have good geometry, no problems on the test stand
#1493
I believe it, and don’t think it had anything to do with the original failure. Like I said I’ve run into this situation before.
| The Following User Says Thank You to Gach For This Useful Post: | ||
#1494
Wayne said that it had happened on mine and Tommys engage but obviously he had never experienced it with factory parts.
#1495
#1496
FYI,in 1963 pontiac offered 1.75 rockers for it 421 SD heads!I have a half set of NOS ones.Tom
| The Following 2 Users Say Thank You to tom s For This Useful Post: | ||
#1497
If the geometry is correct, lift not going to matter. As long as the duration doesn’t exceed 200 at .200 lift thats when the issue manifests itself. I doubt his hydraulic roller was.
Here’s what I did fine to be a issue, I’ve found 2 blocks that the lifter bores had hair line crack. Remember certain lifter bore are attached to the block like a cup handle. 2 and #6. I think #2 let go on his block.
#1498
Yes it was #2
#1499
Back on the road. For some reason the hydroboost seems a little spongier than it was before but maybe it’s just my mind playing tricks on me
#1500
Good job.
