EFI Tech All things EFI and making classics modern!
Old 06-14-2023, 07:00 AM
joes455 joes455 is offline
Default 96 chevy 5.7 vortec timing
I don't know where else to post this ? I HAVE A FOXWELL 630 PRO SCANNER AND MY CAM CRANK CORRELATION IS READING -15 degrees but the thing is I'm not getting a p1345 code,but if I try to add timing I get the code.What is going on?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 06-14-2023, 07:05 AM
Timing should be 0 +-2 degrees,could I be a tooth off and if so why is there no 1345 code?sorry for the 2x question
Old 06-14-2023, 09:49 AM
I would say your summation that this thing has jumped a tooth is probably a good place to start. I'm not familiar with the vortec distributor. I would assume the cap is pre-phased, but you may want to check that as well.
-Jason
1969 Pontiac Firebird
