Old 07-18-2023, 12:02 PM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
Default 67 Firebird Sail Panel Question
The right side sail panel is loose and bowing out so I removed it to check what is underneath. Looks as if the critters have had a good time chewing the jute backing.
I'm planning on adding more jute then holding the middle in place with velcro.
However, in the body, there is a hole with tabs. Not sure why the hole was there but did the factory use the tabs to hold the sail panel in place?
Old 07-19-2023, 03:59 PM
limejudge69's Avatar
Yes the factory used metal clips to hold the sail panel in
https://www.ebay.com/itm/23472827756...970f25c1fc66a5
The Following User Says Thank You to limejudge69 For This Useful Post:
