Old 01-18-2024, 03:08 AM
SD421's Avatar
SD421 SD421 is offline
Default Drag Racing The TriPower Technique Question
So here’s something I have never heard discussed.
As you are watching the Christmas tree countdown are you revving the motor up with just the center carb or do you have all three open?
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 01-18-2024, 08:20 AM
Keith Seymore's Avatar
Stick or Automatic?
K
'63 LeMans Convertible
'63 Grand Prix
Old 01-18-2024, 12:25 PM
SD421's Avatar
Hi Keith,
Stick
1966 GTO
KRE Tri-Power
Old 01-18-2024, 11:05 PM
wolf's Avatar
wolf wolf is offline
I'm at 5600 RPM on the 2 step at WOT.
The Following User Says Thank You to wolf For This Useful Post:
Old 10-01-2024, 01:59 PM
elefantrider's Avatar
elefantrider elefantrider is offline
Center carb. After the light goes green, it depends on the traction and power. What setup do you got?
Old 10-02-2024, 12:30 AM
SD421's Avatar
It’s in my info below
1966 GTO
KRE Tri-Power
Old 10-02-2024, 11:12 AM
I'd say nothing to worry about!
But seriously, on any manual tripower's I've owned - even stock ones - holding the secondaries open with the clutch disengagaged would hit redline in no time..
The Following User Says Thank You to elefantrider For This Useful Post:
Old 12-27-2024, 06:05 PM
Radman's Avatar
Radman Radman is offline
I hold the RPM at 2000. 2nd yellow from the bottom side step the brakes and nail the gas pedal.
Car info:
1962 Tempest
1961 389 Tri-power
700R4 transmission torque converter stall is 2200
Ford 9 inch 3.50 gears.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
The Following User Says Thank You to Radman For This Useful Post:
