Old 02-24-2024, 01:16 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Default 1970-2 vs 1973 rear bumper brackets
Until I can find a usable set of '73 rear bumper brackets, can one use the '70-2 repro brackets and mount it?
So long, farewell.
Old 02-24-2024, 07:35 PM
Norwood's Avatar
Norwood Norwood is offline
Never done it but I can’t imagine way you couldn’t
Old 02-24-2024, 08:31 PM
SD73's Avatar
SD73 SD73 is offline
Yup. I've done it and they fit fine.
Old 02-24-2024, 09:14 PM
Good to know. Hopefully I can find the correct one(s) to replace. Maybe only the nut retainers are missing.
So long, farewell.
Old 02-24-2024, 09:29 PM
SD73's Avatar
The big gotcha with the brackets is if they aren't straight to begin with they are a bear to try to fix. I'd say keep the early set on until you can find a near perfect set to save yourself some headaches.
Old 02-24-2024, 09:44 PM
Norwood's Avatar
No one will notice you have the early brkts. Unless of course you tell them.
Old 02-25-2024, 03:00 AM
Formulabruce's Avatar
The quarter panel side brackets sat on 4 "Paint insulators" as we called them at the dealer. One for each bolt, 2 per side.
Factory ones ( you can see them in assy manual, and Parts too), were a thin foam. These did do the job of protecting the factory paint the first time bumper was installed.
The big clips on these side brackets can easily make a deep scratch and let any water to the metal ( even a hand wash in driveway) .
A couple remedies I have used are Electrical tape, and Gorilla tape cut into squares. The originals were a slight sticky back.
We had a roll of whatever GM sent us, but it was about as rugged as the foam.
SO, If you have some fresh paint, I would recommend Protecting it!
" Long may we DRIVE !"
Old 02-25-2024, 09:37 AM
grd777 grd777 is offline
Angry
good advice, but to late for me
Old 02-25-2024, 02:32 PM
4birds's Avatar
4birds 4birds is offline
Default 73 Rear Brackets
Mike, I have an extra set of the taller brackets off a 73 Firebird.
Send me a PM.
Old 02-26-2024, 05:42 PM
Already have some squares made...
So long, farewell.
Old 02-26-2024, 07:22 PM
cdnroundport cdnroundport is offline
I swap the end brackets side to side it allows you to get a wrench in from the bottom to give that extra little movement to tweak the bumper fit/tilt on the ends
Old 02-26-2024, 07:57 PM
Anyone know what the OE plating/paint is on the brackets?
So long, farewell.
Old 02-27-2024, 12:19 PM
unruhjonny's Avatar
does anyone have length measurements to identify which is which?
Asking for a friend who might have brackets, but doesn't know how to identify one from the other.
1970 Formula 400
Old 02-27-2024, 12:27 PM
I have a few sets, but not right here in front of me. The DO have Part numbers, which I would look at because I have seen used ones as a "mixed" set, which isnt good.
Old 02-27-2024, 12:51 PM
What did you choose to make them out of Mike? My Buddys 70 will be needing some, and he wants more than my 2 options, TY
Old 02-27-2024, 06:58 PM
Send me a PM.
Never new the 73 were different .what was the reason
Old 02-27-2024, 07:28 PM
unruhjonny's Avatar
the bumper standards changed for 1973.
That's why:
1) 1973 cars have a different front bumper
2) all 1973 cars had rear bumperettes
1970 Formula 400
Old 02-27-2024, 07:30 PM
That's why:
Yes makes sense now thanks for your reply
Old 02-27-2024, 09:02 PM
The 73 Firebird bumpers were spaced about 1" further away from the body for collision protection.
(if I remember correctly)
Old 02-27-2024, 09:09 PM
No actual lengths yet, but the difference was around an inch. Stamped part numbers (if readable) is 477xxx for the 1970-2 and 488xxx for the 1973. If still on the bumper, I would look for the dimples on the brackets around the license plate. I circled things that may indicate a '73 set.
This thread may help too.
https://forums.maxperformanceinc.com...d.php?t=767670
So long, farewell.
