Old 05-07-2024, 06:28 AM
Apsesia Apsesia is offline
Default 63 lemans rear end
Looking for a higher geared rear end for an automatic lemans. I have access to a 3.30 gear but a 3.50-3.70 would work better for my setup. Anyone have any? Thanks
Old 05-10-2024, 05:20 PM
firefour1 firefour1 is offline
Contact Ken Glades at [email protected]
He used to own / operate East / West Auto Parts and is pretty knowledgeable about what is available. Good Luck with this and let us know how it turns out.
Old 05-10-2024, 05:25 PM
Also, check out this posting, specifically #'s 52 & 53, this guy has done some great work on a 62 Wagon differential.
https://forums.maxperformanceinc.com...=856589&page=2
Old 05-11-2024, 11:38 AM
elefantrider's Avatar
elefantrider elefantrider is offline
I have a whole rear working '63 2sp transaxle assembly , axle to axle. It is heavy!
Old 05-11-2024, 01:13 PM
Do you know what the gear ratio is or have the letter located on the right side? Where are you located?
Old 07-07-2024, 02:19 PM
I don't know the rear gear but they usually had freeway gears in the 2sp automatics.
Old 07-13-2024, 03:57 PM
R 70 Judge's Avatar
Yes, very heavy. Loading it was not fun
If he’s referring to my old rear end it was a very original 91,000 mile 1963 Le Mans 326 2barrel with a 2 speed auto. I don’t remember the rear ratio but imagine someone here could tell you what the car would have come with. It was still working great when it was removed.
James
1970 Trans Am
Old 07-13-2024, 07:05 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
The 3.30 is higher geared than the 3.50 or the 3.70. The lower the number the higher the gear.
Old 08-26-2024, 01:40 PM
TravisR TravisR is offline
I have a working transaxle two speed automatic with 2.53 gearing.
