Old 09-27-2024, 09:13 AM
djustice's Avatar
djustice djustice is offline
Default New line of camshafts at butler, max HP series.
Looks fairly agressive, i'll be bench racing these in my head.
https://butlerperformance.com/c-1459...ollercams.html
Murphy's law - "Anything that can go wrong will go wrong".
-469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++
The Following User Says Thank You to djustice For This Useful Post:
Old 09-27-2024, 09:44 AM
PAUL K's Avatar
PAUL K PAUL K is offline
The old Stage 1,2 & 3 deal.
Interesting, I've seen the specs for the World's Fastest NA Pontiac, turbo charged Pontiac and supercharged Buick and none of them were close to the specs on that link..... Things that make you go hmmm.
Thanks for posting
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
Old 09-27-2024, 10:21 AM
zippy's Avatar
zippy zippy is offline
This has me ??? Lobe sep is ground into cam and cant be changed
BP/Comp Recommended Cam Degree
For 110 Lobe Sep.- Install Int. Lobe CL to 106
For 112 Lobe Sep.- Install Int. Lobe CL to 108
For 113 Lobe Sep.- Install Int. Lobe CL to 109
For 114 Lobe Sep.- Install Int. Lobe CL to 110
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 09-27-2024, 11:30 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yep.
112 sep at 112 icl is “straight up “. 108 would be 4 degrees advanced.
Old 09-27-2024, 11:38 AM
rjpaige3 rjpaige3 is offline
It makes more sense if you replace "for" with "if". Whichever cam you get, install it 4 degrees advanced.
Old 09-27-2024, 02:00 PM
In the For 110 Lobe Sep.- Install Int. Lobe CL to 106 example, the 110 Lobe Sep. is the Lobe Separation Angle (LSA).
This is angle between the Intake lobe and the Exhaust lobe. (not changeable)
The Install Intake Lobe CL is the Intake Lobe center installed at 106º. (for 110º it would be Int & Exh both at 110º)
This can be changed. But it also has the Exhaust Lobe 110º separated from the Intake Lobe still, but the Exhaust Center line will be different due to the whole camshaft being advanced.
Old 09-28-2024, 11:12 AM
zippy's Avatar
Ohh I get it now LOL DOHHH
Dan Pesonen
Old 09-28-2024, 01:23 PM
i82much's Avatar
i82much i82much is offline
why does the lobe lift stay so consistent as the durations go up? valve spring availability?
