Old 10-08-2024, 10:13 AM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Default Rear Main Seal Leak Problem Solved!!
Saw this on one of my FB Pontiac groups. Don’t know if this guy is for real or just posting to see what kind of responses he gets. Thought you guys might enjoy this. Sooooo, for your edification:
To fix your Pontiac's leaky rear main seal, try this alternative solution: attach a small plastic jar to the bottom of the dust cover and drill a hole in the lid for oil drainage. When the jar is full, simply unscrew it from the lid and empty it. Saves the trouble of pulling the engine just to have it happen again. You can thank me later.
ID:	641045   Click image for larger version
ID:	641046   Click image for larger version
ID:	641047   Click image for larger version
The Following 4 Users Say Thank You to 64-3Deuces For This Useful Post:
Old 10-08-2024, 10:29 AM
77 TRASHCAN's Avatar
Man, what a genius!!! I hope he applies for a patent!!!
He needs to get with the guy that came up with the in line PCV hose, oil catch can. Maybe they can market them together, Make it a two-fer purchase!!!
Shut it off
Shut it off
The Following 2 Users Say Thank You to 77 TRASHCAN For This Useful Post:
Old 10-08-2024, 11:42 AM
72projectbird's Avatar
Hah
You laugh, but they make something similar for turbo Buicks. They love to leak out of the rear main too
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-08-2024, 12:30 PM
jhein's Avatar
jhein jhein is offline
LOL. Now, if you could put in a line with a filter and return it back into the oil pan you'd be all set!!
The Following 3 Users Say Thank You to jhein For This Useful Post:
Old 10-08-2024, 12:52 PM
Obviously GM injuneer...lol
Old 10-08-2024, 01:46 PM
64-3Deuces's Avatar
Hah
Interesting. Maybe that's where he got the idea.
Old 10-08-2024, 01:48 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
GNs have the Spoolfool diaper, it uses 3 folded up paper towels to trap the oil, literally.
This isn't a solution, it's just a way to stop the embarrassing leak.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 10-08-2024, 05:25 PM
Bill Hanlon's Avatar
Sometimes that is enough.
Old 10-08-2024, 06:04 PM
I saw this; what a great idea!
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 10-08-2024, 07:04 PM
Still it will not stop the churned up oil mist due to no real sealing of the flywheel cover to the the trans and the rear of the motor.
Old 10-09-2024, 12:19 AM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
I would be curious if it simply kept it from getting all over the underside of the car. I don't really lose my mind over tiny seeps on the ground, its an old car, it does what it does. But I do hate all the grease and grime that accumulates on the chassis from leaks.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 10-09-2024, 06:38 AM
grivera's Avatar
grivera grivera is offline
The deluxe version is a black jar so it blends in with the undercarriage
Will Rivera
The Following 2 Users Say Thank You to grivera For This Useful Post:
Old 10-09-2024, 01:01 PM
rohrt rohrt is offline
That makes me want to try again to use the converter cover again. Mine is bent to hell and and the converter bolt hit it.
Not that I'm going to glue a container to the bottom, but it would be nice to not have my flex plate flinging oil everywhere.
Old 10-09-2024, 02:22 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Put a sump under there and pump it back into the engine!
I put an old piece of drywall under and that drip. Anything more than a drip gets fixed proper like.
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 10-09-2024, 03:19 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
For over 20 years my car has left a couple drips on the floor every winter during storage. Dime size spot, not a major leak.
My car club asked me to enter the car into an indoor car show that the club partakes in every year in the winter months. We have a real nice display including carpet that the cars park on. I did not want to be the guy that stains the carpet, so I build this to prevent any issues. I leave it on all the time and change the mat every time I change the oil.
Cheaper and easier than replacing the rear main seal. Don't flame me to bad, LOL...
ID:	641074   Click image for larger version
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
The Following 4 Users Say Thank You to Bob with the 66 For This Useful Post:
Old 10-09-2024, 03:28 PM
jhein's Avatar
That's slick! It looks like you can replace that absorbent material without removing bracket. Nice. I bet you could sell them.
Old 10-09-2024, 04:02 PM
Thumbs up
G E N I U S
Cheaper and easier than replacing the rear main seal. Don't flame me to bad, LOL...[/QUOTE]
Old 10-09-2024, 05:53 PM
Pontiac Performance Author
That wouldn't be a Maxi Pad in there, would it?
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 10-09-2024, 06:25 PM
steve v's Avatar
steve v steve v is offline
Yeah, this reminds me of the shady used car dealer that would stuff a tampon inside the convertor cover on cars w/leaky rear mains.
Old 10-09-2024, 06:40 PM
65madgoat's Avatar
Honestly just stick PIG MAT between your MANUAL trans bellhousing and block and leaks will be absorbed by it. All most need unless your rear main seal has been totally ripped out.
And someone does have a patented diaper for SBC motors:
https://www.ebay.com/itm/165245967503?
The Following 3 Users Say Thank You to 65madgoat For This Useful Post:
