Old 10-18-2024, 11:36 PM
SD421's Avatar
SD421 SD421 is offline
Default Weird Dash Light Gremlin
Hi Anyone,
Dash Lights work when the ignition is off but turn the key to “RUN ” and even START position and they go out.
Any ideas?
Thanks,
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 10-19-2024, 01:53 AM
SD421's Avatar
It was the dash black ground wire at the pedal bracket.
It wasn’t grounding properly.
1966 GTO
KRE Tri-Power
The Following User Says Thank You to SD421 For This Useful Post:
Old 10-20-2024, 11:28 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Glad you got it figured out, was gonna comment about a Ground issue, but not a 66 guy so was waiting for others to comment, but you got it handled.
Nice work. Bad grounds do weird things.
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 10-21-2024, 09:56 AM
pfilean's Avatar
pfilean pfilean is offline
Grounds will drive you crazy. For most unexplainable electrical problems look at the grounds. Had a problem on an old truck recently. Turn on the parking or headlights an everything in the dash would come on. Turn indicators. high beam indicator, everything on made it look like Christmas. Activate a turn signal and it would over ride the signal and flash it all. Cleaned up the light grounds on the core support and that seemed to fix it all. I hope.
The Following User Says Thank You to pfilean For This Useful Post:
