OHC-6 TECH Over Head Cam projects, questions and advice.
Old 11-04-2024, 01:22 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Its been a while since I've updated this thread. I've poked at the car a bit over the last few months but had been side tracked with work on my Skylark. I organized and loomed up most the wiring under the hood. Still need to connect all the wire ends to pigtails.
Put in the separate "high" power connector (blue) that brings 12v into the cabin and power out to the coils and injectors. Also added bulkhead connectors for EFI manifold vacuum and the boost controller.* So not just running a line through the firewall.*
I've just been really unhappy with the hard transmission cooler lines I had made and have yanked them all out and punted by ordering some braided flex line. I had mounted the transmission cooler to the front side of the radiator, but decided to move it to the backside of the inter-cooler so if I have to pull the radiator for any reason I could leave the ATF lines connected. I have strips of rubber tubing insulating the two coolers from one another.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
The Following 2 Users Say Thank You to TheSilverBuick For This Useful Post:
  #442
Old 11-07-2024, 01:06 PM
66sprint 66sprint is offline
Randall, looking back on how this project has evolved, is there anything major that you would skip or do without if you were to do it all over from the start?
  #443
Old 11-08-2024, 06:24 PM
I wouldn't drill the side of the head for the external oil line. I will always run a straight pipe in place of the oil restrictor and external oil pressure regulator, but will feed it to the back of the head like I've done on the new build. I had to block one of the head oil drain back passages to accomplish this. Technically I don't believe that should be an issue, but may be related to another issue I mention below.
I'm 50/50 in the air on the electric water pump. It was a requirement before because the first EFI intake I made would not allow the thermostat housing to remain in place. That being said, there are a few advantages to running an electric one. Namely full water flow in stop and go traffic, with electric fan, guarantee a cool running engine, and if the water pump fails another motor can be gotten from Summit Racing (and I bought a spare motor for 50% off their discount rack), and when racing other people may have the same pump as a spare. That being said, mechanical pumps are simple and typically work reliably for a long long time. I went back to conventional "block to head" water flow with the new build because the modified core plugs always concerned me and the plumbing was more complicated.
New setup. The water pump plumbing would be simpler if I had a single outlet pump instead of dual, but its what I already had on hand because the last arraignment.
Then lastly the external oil pickup line and drain back lines. I have my reservations on it, but obviously going to try it. If it fails or gives me trouble I will remove it, remove my custom windage tray and install a conventional pickup tube. From day one, with a factory pickup and pan I've had a severe oil pressure drop on the 1-2 shift. Every time, even with an extra quart in the pan. So I'm hoping with good baffling in the pan, moving the pickup rearward a bit, and an extra 1/2" of pan depth allowing more oil to be ran if necessary, I'll have that issue fixed. I had filled in one of the head oil drain back passages, so there is a chance a lot of the oil was up in the head and not returning to the pan fast enough, but I'm not convinced of that. If I still have oil pressure issues on the 1-2 shift I'll have some thinking to do. On the drain backs, by the time I changed my mind on doing it I already drilled the block so its done. I did the external lines to keep the oil from dropping on the up-swinging crank, so to reduce oil windage.
On the EFI side, I wouldn't change a thing other than just being less of a hack. I was experimenting with a number of ideas and things and it shows. The one thing I would possibly consider different if I were building a N/A multiport EFI build with no one off intake manifolds is having intake spacers made with the EFI bungs casted in. They didn't exist when I did my conversion back in 2014, but ideally would space the intake manifold out enough to lay over the the injectors enough to clear the thermostat housing.
They are a little pricey. If I got them I'd probably have a center divider welded into them and because they are for a Chevy probably would need a bit of porting to work on the OHC.
  #444
Old 11-08-2024, 07:23 PM
Non-OHC related, I would of put the 4L60e from the beginning. Though the lighting rod shifter is blink'in awesome it doesn't do much with the 4L60e as there is serious lag between pulling the lever and the shift, still cool to use it to hold 2nd gear or such to wind up the engine a bit with light throttle, but no use for racing now. Just put it in D and mash the pedal, the programming will handle the shift timing. The 200r4 shifted instantly, but tuning that transmission was a pain in the rear, especially when I was switching gear ratios from 4.56, to 3.42 to 3.89, etc. Or alternatively go straight to a manual transmission (I have 6-speed in the garage).
I would have put a 9" rear axle in it already if I were to start from scratch. Technically nothing wrong with the 8.5", but my Skylark has a 9" and to have the gears, axles, etc interchangeable between the two cars would be nice. That way I could keep a few different gearsets/pumpkins in the garage and swap in the gears I want depending on what I planned for the car. (I'm sure glad I have concrete now!)
Probably wouldn't do a rear disc conversion again either. I've done rear disc conversion on both the Skylark and Firebird and think its over rated for what I do with the car. I may change my mind if I shift focus to auto-crossing or such. Both cars stop great, but the pedal feel is so-so and the parking brake setup is annoying.
  #445
Old 11-09-2024, 08:19 PM
gtospieg gtospieg is offline
X2 on the e-brake with rear discs...never again unless it's "drum in hat".
The Following User Says Thank You to gtospieg For This Useful Post:
  #446
Old 11-14-2024, 10:12 AM
Thanks for the info Randall.
I have looked at the manifold spacers and figured they might work. Just did not like them being open or undivided.
Seeing all that has to be done to Chevy just to get siamesed ports (port lumps, spacers and dividers) makes me appreciate the original Pontiac engineers.
Have you ever looked at a 2 piece Supra manifold and possible making adapters to fit the OHC?
  #447
Old 11-14-2024, 01:37 PM
I would definitely see about welding dividers in, then die grind the ports to match everything up. The other thing about those spacers is I'd buy them WITHOUT the injector holes drilled. I would hazard a guess that the injector angle they are drilled at for the chevy would cause interference with the thermostat housing. You can either have the injector pads cut to a flatter angle, or simply drill the injector holes non-perpendicular to the pad face. The trick would be to find the angle that is allows the injector to clear the thermostat housing without hitting the throttle body. There are now good injectors that are shorter than the ones I was trying out in 2014.
I don't know anything about the Supra intake port spacing or sizes. I've got this Weber Carb intake manifold I put injector bungs in, and if you wanted to run this manifold naturally aspirated then just bolt on some Weber carbs with no fuel lines and it'll run NA just fine. I've got a handful of pieces to build a box, one in steel I can easily weld, and pieces of aluminum plates I can either give it a shot or take to a pro to weld up. I want to get the car up and running again before I change out the intake manifold.
  #448
Old 11-14-2024, 08:18 PM
Ashley P Ashley P is offline
I just found this topic. Wow, good job. I've got lots to learn here.
A conclusion is the result of analysis of information: sound logic must be used, as well as accurate, applicable information.
  #449
Old 11-18-2024, 02:27 PM
Got a few hours in working on the wiring. Finished up the ignition coil and injector harnesses. I'm going to use black wire wrap tape on the pigtails into the main loom. I left the injector wires long knowing I'll be trying another intake later and want to be sure the plugs reach.
I'm using uninsulated butt connectors with shrink wrap. I've pre-crimped a handful of sensor pigtails and stuck the shrink tubing on it so I wouldn't forget later!
The other idea I had yesterday was heating up some number stamps and brand the injector plugs so I don't get them mixed up.
The Following User Says Thank You to TheSilverBuick For This Useful Post:
  #450
Old 11-18-2024, 02:38 PM
I got the transmission cooler saga behind me. I wouldn't call it the greatest solution but ran two hoses from the transmission to the cooler instead of hard line. I did put a about 18" of line from the transmission to the frame so if I have to remove the transmission I can easily separate the lines down by the frame than up on the transmission.
Meh, but it'll be fine and out of site behind the radiator.
I still need to add the hose supports to keep them tied to the body and frame. I just got the brackets I want to use so have to put them on. The hoses have good clearance around all the exhaust.
  #451
Old 11-24-2024, 08:42 PM
Weather has been pretty poor lately, but got a few things done today. Namely wired up the air intake and coolant temperature sensors, crank and cam sensors and main line and lash adjuster oil pressure sensors. I had previously used weather pack connectors on the crank sensor and throttle position sensor, and the connectors have always been problematic for me, so I'm replacing them with pre-made pigtails.
My car will have three or four of these hall sensors on it, so I'm making them all with the same male plug so I can swap them in a pinch, though the crank one has been on the car since 2014 and perfectly reliable. I have one on the crank, the cam sensor, and will put one on a front wheel like my Skylark for traction control. There is another I plan on running to see if I can detect crank flex from the 3 torque converter bolts. Its a long shot but doesn't really cost me anything to try.
I also bought a box of plastic clamps for holding wires and hoses.
I clipped one onto the fan shroud here and should hold the crank sensor wires away from the alternator quite well.
  #452
Old 11-26-2024, 12:33 PM
With my next intake change, I may go to a drive by wire setup. I got the pedal for $10 for my Thunderbird EV conversion, and the throttle body I just picked up at Summit for $60. The controller was $180 after shipping and taxes a year ago. It can run as a standalone "dumb" throttle that follows the pedal movement, but also connects to the Megasquirt via CAN then the Megasquirt can adjust the progressiveness of the throttle opening, control warm up opening, close it for rev limiting, and do nifty things around launch control.
On launch control, it could consistently hit a throttle position during launch control, so I can put the pedal on the floor while holding the launch button and the throttle could be programmed to be opened say 40% to keep intake air speed up to not bog and not over run the foot brake or at least be 100% reliant on the 2-step to hit target rpm. Similarly on WOT versus boost/rpm, because the size of the throttle blade compared to engine size its prone to bogging at low rpm, so I can program in a max opening percentage with the pedal on the floor.*
https://www.facebook.com/1042835976/...5465693993054/
  #453
Old 01-03-2025, 07:49 PM
After going on vacation and having in general poor weather, I've been poking away at wiring.* Connecting up sensors, wrapping the wiring up, and just trying to make it as nice as I can do.
The most obvious change here from previously are the pigtails are wrapped in black now and I've mounted to power solenoid and two large fuses on the driver's fender.
Previously I had the power solenoid on the passenger side with a 10 gauge wire coming from the alternator with a 75 amp MAXI fuse, which went over to a local fuse panel then out to accessories. The 10 gauge wire showed some signs of being cooked* Now I have 6 gauge wire from the starter post (connected to the battery) to the alternator and then up to the power solenoid and out to two large fuses.* I wanted 75 and 100 amp fuses, so need to swap the rear fuse. The frontmost fuse is for the radiator fan, electric water pump, and any always powered accessory in the stock fuse panel. When I convert the headlights to local relays, they'll get their power from this fuse as well.* High load stuff. The rearmost fuse is the EFI and chassis power fuse blocks.* Its a 140 amp alternator, and of course battery power.*
Since the weather has been poor I've been working on the dash. I've removed the mechanical speedometer from the cluster and ran the digital speedo wires through the backside now. Since the blinker and high beam indicator lights are removed I've added three lights between the pods to replace them.* I've also finalized mounting a touch screen in the dash.*
Much cleaner than wires out the front!
These wires run to a connector, and the other side of the connector I'll tie into the dash harness wires.*
For the touchscreen, I've moved from a 7" screen to a 5" that fits the area much better. Its a tad short on height, but with a minor amount of trimming it fit between the existing mounting points. For mock up it just has the screw heads holding the screen in place, but I plan on making some ABS plastic clamps to really hold it down and take up the ~1/8" gap on height. Its a fresh software install so I need to create some new custom digital gauge/indicator layouts.**
Here is a video of the screen in action.
https://www.youtube.com/shorts/DrKLmt6pMI4
  #454
Old 01-05-2025, 11:08 PM
Green Elephant Green Elephant is offline
Great thread and an awesome build, I admire your energy and ingenuity! I’ve always liked the OHC 6 engine. I can recall seeing a 1967 Lemans sitting in a salvage yard in TX during my Army stint in the mid-80’s. Everything was there, right down to the 4 bbl Quadrajet. The car was complete too, not sure why it was in the salvage yard. Definitely one of those cars I wish I would have rescued. Anxious to see this car on the street or strip sometime!
The Following User Says Thank You to Green Elephant For This Useful Post:
  #455
Old 01-06-2025, 03:45 PM
The under hood updates are looking less apparent. Feeling closer and closer there. I installed the fender braces to add to the completeness look.* I've removed the belt cover for re-paint. I've got it and the paint in the house warming up so it'll paint reasonably well.
I plumbed in the vacuum/boost lines in and wired in the crank case and coolant pressure sensors.* I still need to wire up the O2 sensor and water pump.* The heater in the O2 sensor is electrically noisy so I wanted to have everything wired in before so I can keep it as electrically separated as possible.* The thin yellow wire up front is for an alternator ammeter sensor that I have mis-placed and keep hoping it'll turn up. Either way its non-critical.**
I did have a minor setback.* I noticed the intake manifold was in contact with the #1 header pipe. The locating dowel on this head must be slightly lower than on my other head. I do recall having some issues bolting the intake on and now I know why.* Worse case the intake wasn't sitting flush on the head, less best case the intake is getting direct exhaust heat. So I cut the corner off the throttlebody flange for some clearance. I do like how easy it is to pop the intake off. Unclip the injectors and TPS, disconnect throttle cable, unhook fuel line and remove six easy to get to bolts.*
Before the EGT probes I used to be able to get wrenches on the bolts, but using a 1/4" drive socket and swivel makes it easy to get to all 6 bolts.*
Where the intake was contacting the exhaust. There is a little dimple in the exhaust tube from some self clearancing when tightening the intake down.*
Corner zinged off. Its still close, but its not touching, which is good enough for me.*
Been a while since I posted a picture of the whole car. Its still there.* Under the hood I need to hook up the O2 sensor, water pump with PWM relay, hook up lash adjuster oil by-pass return and plug a water pump port and under hood will be done.* I plan on getting the hood tach back together the next time the weather is bad. I have some bondo I want to coat and smooth the hood tach housing and find some reasonably close spray paint for it.* *In side the car still needs help. Have to finish up the screen mounting in the dash panel then can really start on the interior work.* I have new carpet for it, so I think I'll pull the seats and console out for more working room, do all the wiring then lay in new carpet. Might pull the kick panels out for a clean up and re-paint to black (from dark green).**
  #456
Old 03-10-2026, 12:03 AM
My fairweather updates. I'm sad that I should of had this thing up and running a couple years ago now, but I can at least say I'm still making progress. Most the underhood wiring is done. I still have to tie in the electric water pump and the hood tach, but otherwise should be functionally done. I started on the interior and well more scope creep.
Ran new wires to the trunk area through the sill panel conduits. Including the speaker wires, always on 12v battery power wires from the trunk battery, fuel pumps relay trigger wires and two spares for other uses.
Patched the giant holes in the trans tunnel.
New carpet. Once in I used a heated up pipe to melt/cauterize holes for the seat belt bolts, etc.
[img]
Pulled out both kick panels and painted them black. Ran all the wiring that goes to the rear through the factory wire conduits in the door sills, patched some holes in the floor pan and installed new carpet.
For the kick panels, I cut off the vent tubes, added tabs to bolt the tube in place and this should allow the kick panels to be removed more easily in the future. Particularly if I put a cage in it.
  #457
Old 03-10-2026, 12:19 AM
Put the dash back in. Turns out the reproduction dash pad uses metric hardware and didn't come with the clips that the dash panel screws into. I also 3D printed a screen holder for the touch screen that goes were a factory clock would go. Not the most ideal angle, but when its running and driving I'll make adjustments to the fonts and gauges to make it easier to read at a glance.
Installed a pair of front speakers. Not perfect stereo, but better than nothing that was there before.
A raspberry pi with touch screen bolted to the dash.
The dash didn't come with the plastic clips, so I drew some up in Fusion360 and printed some out.
The touchscreen layout is editable remotely via wifi. So I'll be able to adjust the fonts, colors, change read outs to gauges, etc.
Video of it in the car
https://youtu.be/NG2Qx03vOuw
Video of making adjustments remotely.
https://youtube.com/shorts/J1nNV3DK-zs
  #458
Old 03-10-2026, 12:33 AM
Now, I really need to get it up and driving around before I start making other changes, but I got a 3D scanner and a 3D printer in the last 4 months and have been playing around with making a new intake manifold that would bolt to the Weber intake.
3D scanned the Weber intake, sliced the flange, digitized it and drew a new flange in Fusion360.
Made some velocity stacks for the ports, then boxed them in.
I designed it so the bottom would bolt on with an o-ring seal, and the first cylinder would get more air than the current manifold. This is first iteration, there is some cleaning up that would have to be done for a final manifold. I made a go at printing it in cheap PLA, but had an issue with the print. I need to do some printer calibration for the filament I tried to use. I fill try a more suitable ABS or such type plastic when I decide to run one. Or still proceed with a metal manifold to weld together that I can make patterns off of in CAD.
I scanned a DBW throttlebody I have to use. Added it to the model. The youtube link at the end is me testing out the DBW on the bench.
DBW bench test
https://youtu.be/o_jKjEXdHVE
  #459
Old 03-10-2026, 12:36 AM
Then last weekend after I put the dash in and did some minor wiring, I hot-wired just the fuel pumps and fuel pump relays to drain all the old gas out. Surprisingly it didn't smell bad, but either way, I'll put fresh 91 in when I get ready to fire it up.
  #460
Old 06-04-2026, 04:27 PM
I believe I've finished up the core wiring to start and drive the car. I'll wire up the radio and a few small accessories (like USB power ports, etc) later when its on the road. I did a run through checking fittings and looking for anything that may be un-plugged. So theoretically it should be mechanically and electrically ready to go, but going to do a few more checks before adding fuel and spark.
Next steps are doing a wiring check with an ohm meter to be sure there are no dead shorts from the battery and some power/ground checks on the ECU plugs. If it clears that, I'll connect the ECUs (engine/transmission), and then do a sensor and function check. Sensors reading correctly, command the water pump and radiator fan, etc. With that, I'll command each injector and ignition coil individually to see I have wired them in correctly. If things are still checking out, I'll crank the engine with fuel/spark off and see the crank and cam sensors are reading correctly. When all those parts check out, it should fire up and idle like a new car with the old EFI tune.
When periodically priming the oil system (and rotating the engine around) I had a leak on the turbo oil drain fitting. I tried to RTV the "hole" in place, but it didn't work so I removed it to verify the leaky section and seal it up on the table.
I brought the engine around to the #1 compression stroke and lined the trigger wheel up 3 teeth before the missing tooth (~30º) to set the cam sensor in place. The cam sensor needs to be picked up a reasonable distance before the missing tooth to tell the ECU its on the #1 compression stroke.
I have this small window a plug fits in to view the alignment between the cam sensor and trigger tooth.
