Old 03-08-2025, 10:50 AM
GordonGeesey GordonGeesey is offline
Default Hood Spring Help
When I bought my '69 GTO it had already been restored. I immediately noticed that the hood springs were really "weak" - meaning that they barely kept the hood raised. Any slight breeze or even opening the door and sitting in the car when the hood was raised would cause the hood to come crashing down.
So I purchased a reproduction hood hinge & spring kit. I was disappointed to find that once installed and aligned properly, the situation only slightly improved. The hood still closes much too easily. It's bad enough that I'm afraid to raise the hood at a cruise-in or show for fear that the hood will slam down on someone.
Does someone make a set of "heavy duty" springs for my car (or know of another set of springs that'll fit) that might solve this issue?
TIA for any advice!
Old 03-08-2025, 12:11 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Buy the Ames springs part # D130. I had the same problem. Put these on and problem solved.
Old 03-08-2025, 01:11 PM
tooski tooski is offline
Same problem with my 68 Firebird. Stock replacement from Rock Auto fixed it.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 03-08-2025, 08:01 PM
Ames doesn't list Part # D130. The only hood springs they list say that they're for a Firebird.
Old 03-08-2025, 08:03 PM
Rock Auto doesn't list any hood springs for a 69 Goat. Do you know your Part #'s by any chance??
Old 03-09-2025, 09:35 AM
Looked on line and couldnt find D130. Went to their actual paper catalog and they list it? Finally figured out that D130 is the application for 66-67 GTO's. Since I was searching for hinges for a '69 it never showed up. LOL
Springs are ordered, and fingers crossed they solve my issue. Thanks for the guidance!!
Old 03-09-2025, 06:04 PM
hakansan's Avatar
hakansan hakansan is offline
Here is what You need!
https://www.amesperf.com/parts/searc...lts/?term=d131
`70 GTO, 370 hp, 3:90, TH400.
Old 03-09-2025, 10:37 PM
Originally Posted by hakansan View Post
That spring wont do him any good. The D130 is a stronger spring and will work good on his loose 69 hinges. Been there done that.
Old 03-25-2025, 12:28 PM
Update: The D130 springs were ordered and installed. They seem to have solved the issue! Thanks to everyone who weighed in to help!
Old 05-10-2025, 08:30 PM
Red Box Rebel Red Box Rebel is offline
I had the same problem with the Original Hood Springs for my '68 GTO. I bought the AMES new springs and assemblies. They barely hold the hood up. Very disappointing.
Old 05-10-2025, 09:20 PM
tom s tom s is offline
My 69 bird had the same issue,I found some Volvo springs that fit inside the stock GM springs and it cured it.Can be installed with the originals on the car.Tom
Old 05-14-2025, 06:18 PM
grivera's Avatar
grivera grivera is offline
Hi Tom- I have the same issue with my bird - do you have a part number for the ones you used?
Will Rivera
Old 05-14-2025, 06:26 PM
I dont,been a few years.I did a search at the time,will see if I can find it.Tom
Old 05-14-2025, 06:47 PM
I think they were Volvo 140-142 springs.They fit inside the firebird springs.No guarantee but they look like what I used.Tom
Old 05-14-2025, 08:36 PM
grivera's Avatar
Thank you
Will Rivera
