Old 04-12-2025, 01:22 PM
jhnichols2 jhnichols2 is offline
Default 64 Lemans trunk lock retainer
Were there two types of trunk lock retainers for 64? I removed one yesterday from my trunk lid and it is curved. i also have one bagged and labeled that is straight. The straight style is what I see reproduced for 64-65.
ID:	650180   Click image for larger version
Old 04-12-2025, 03:46 PM
Yes there were two types, I have seen both styles in my parts collection.
Old 04-17-2025, 11:37 AM
Dick Boneske's Avatar
Default Trunk Lock Retainer
We just disassembled the trunk lock assy. on our '64 GTO. Turning the key was very difficult---to the point that we were afraid the key would break.
We determined. that the problem was the retainer referred to in this thread. If I tighten the screws that hold the retainer in place, the problem occurs. The solution was to just snug the screws, mildly compressing the rubber gasket. When left like this, all is well. If I had known this in advance, no disassembly would have been necessary.
The retainer we have is the curved one. I assume it got bent at some time, causing the problem. This is one of the many areas we need to be careful, since most all of the parts for this trunk lock assy. are not available.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-17-2025, 04:48 PM
GtoFM's Avatar
GtoFM GtoFM is offline
My '64 also has the curved type. It needs a gasket, and I have not been able to locate one. What material is recommended to fab one?
Old 04-17-2025, 06:59 PM
The gasket is rubber-about .060” thick. It looks like rubber from an inner tube. Cut a rectangle the same dimensions as the retainer portion that contacts the trunk lid. Poke two holes for the screws and you’re set. Simple to make.
BONESTOCK GOATS
Old 04-18-2025, 10:31 PM
GtoFM's Avatar
Thanks DB!
Old 04-27-2025, 09:11 PM
John V. John V. is offline
Dick, that is a great tip concerning loosening the screws (the gasket solution is also a great tip).
My key is also extremely hard to turn which has also made me fearful of snapping the key.
I will give your solution a shot, hopefully it will solve my issue same as it did for you.
Thanks!
