Old 08-19-2025, 09:37 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Originally Posted by 79 Phoenix View Post
Hi Chris--Nice to meet you too! That was a nice show with lots of nice cars. I've never been to an all-Pontiac show. Planning on returning next year. Are you from SE PA?--Kim
PS--Now I remember! You are from Ocean City. Right??
Yes, I live in OC. Funny about the driveshaft vibration you mentioned, I have one myself I'm trying to figure out. I was thinking rim or tire but I'll have to give mine a closer look.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #342
Old 08-19-2025, 12:14 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Yes, it wasn't off by much. I loosened and re-centered the u joint so the caps stick out equally on both sides.
  #343
Old 08-19-2025, 04:23 PM
400 Lemans's Avatar
The 3r u-joint centers itself with no movement side to side. Are you sure the inside clips are installed?
  #344
Old 08-19-2025, 04:35 PM
79 Phoenix's Avatar
It has the C clips to hold the u-joint in place on the driveshaft and front slip yoke. But where mine was off was on the pinion yoke. Every other driveshaft I have ever installed has had ridges on the pinion yoke to seat the u-joint caps and assure the u-joint is centered. Mine doesn't have any ridges.
  #345
Old 08-19-2025, 04:57 PM
johnta1 johnta1 is online now
Does it have a cap or a u-bolt?
The caps had a tang to center the u-joint, because the pinion didn't have the tang.
  #346
Old 08-19-2025, 05:44 PM
400 Lemans's Avatar
Yeah the pinon yoke gets C -clips on it also so it centers it. If there not there then the ujoint will move on you eventually.
  #347
Old 08-19-2025, 05:53 PM
I had the same issue sadly:
https://forums.maxperformanceinc.com...&postcount=151
  #348
Old 08-19-2025, 07:31 PM
79 Phoenix's Avatar
Okay, thanks guys. I need to look closer at this. It will have to wait as I'm going out of town for a week. I will get on it when I get back. Thanks again. --Kim
  #349
Old 08-27-2025, 02:32 PM
79 Phoenix's Avatar
I have verified that all the u-joints have the c-clips and the pinion u-joint is held on with u-bolts.
I had originally installed the driveshaft with new u-joints last Fall. It drove without vibration then. Then in February I had to remove the transmission to replace the throw out bearing and think (hope) I just reinstalled the driveshaft off-center. Vibration started after re-installation. Now that I've centered it, it drives fine.
Here are some pictures... Does anyone see any problems?
Name:	u joint 14.jpg
ID:	656251   Click image for larger version
Name:	u joint 11.jpg
ID:	656252   Click image for larger version
Name:	u joint 12.jpg
ID:	656253   Click image for larger version
Name:	u joint 13.jpg
  #350
Old 09-01-2025, 08:31 PM
79 Phoenix's Avatar
I took the plunge! Taking the dash apart. The plan is to clean everything; clean the cluster; replace all the bulbs; paint the silver part of the bezel; install woodgrain on the bezel; fix one crack on the dash pad; paint the dash pad and re-assemble before the 14th... because I have an appt to get passenger outer wheelhouse and partial quarter installed the last half of the month. So, I need to keep moving on this.
I need to unhook wires to courtesy light switches or uninstall switches and get the whole pad off the car and then to figure out how to remove bezel and cluster. Any suggestions or tips would be welcome!
Anyone know if I can replace bulbs with LED's?
ID:	656513   Click image for larger version
The Following User Says Thank You to 79 Phoenix For This Useful Post:
  #351
Old 09-02-2025, 07:23 AM
67Lemons 67Lemons is offline
I installed LED’s in my dash cluster when I pulled it this spring. Search here for some threads, there were some really good threads on removing the dash in the ‘70-‘72 cars, it’s not hard, just requires patience.
Edit found:
https://forums.maxperformanceinc.com...t=Dash+removal
1972 GTO
  #352
Old 09-02-2025, 08:56 AM
79 Phoenix's Avatar
Thanks 67 Lemons. for the great link. I had done previous research but had not come across that thread. Fortunately, I have already accomplished that much. I just need to disconnect the dome light switches. and then pull the unit out and work on the bezel and cluster.
I plan on using SEM Color Coat Satin Black on the pad after I fix a small crack. As far as I can tell, the Satin should be the closest to original.
So, do the LEDs work well in yours? Not too bright?
The only lights that currently work on mine are the speedometer lights, But ,they are very dim. But they have been in there for at least 45 years!
  #353
Old 09-02-2025, 10:58 AM
Only issue I have had with LED instrument lamps was they do not dim.
  #354
Old 09-02-2025, 12:28 PM
Shiny Shiny is offline
Like Scarebird says, they may not dim at all or dim the way you want.
You can certainly use LEDs but get specifics from someone that used them and is happy. It may be tricky to get the right "light output power" and the "color" can vary.
You may need to re-do the blue reflector paint in some of the gauge backs.
Not a 70 Tempest, but this may offer some insight:
https://forums.maxperformanceinc.com...highlight=1891
It has been almost 10 years since I went through my dash, and I chose to stick with incandescent lamps.
Here are some notes I took, but they are incomplete. No guarantees about accuracy so double check:
There are several threads on here that suggest alternative lamps that are brighter. The tradeoff will likely be hotter and less life. Here is another chart I pulled out of my notes that details some of the differences. For example, 168 is sometimes recommended as a brighter option for 194 and is what I installed:
ID:	656530   Click image for larger version
  #355
Old 09-02-2025, 01:10 PM
79 Phoenix's Avatar
Thanks for pointing this out! I had forgotten about the dimming issue.
  #356
Old 09-02-2025, 01:20 PM
79 Phoenix's Avatar
Thanks Mike! Very helpful information and link. I'm thinking of staying incandescent due to the LED dimming issue and also having more uniformity in the brightness. If I could only get some in LED and not others it would look weird...
My Gt-37 is a base model and doesn't have some of the lighting...ashtray, glovebox, etc. so I don't think there will be that many bulbs to locate.
  #357
Old 09-02-2025, 05:50 PM
79 Phoenix's Avatar
Thanks Mike for this very helpful info! I'm thinking of staying with incandescent because of the LED dimming limitation and to try to maintain some uniformity in brightness. My GT-37 is a base model so it doesn't have some of the optional lighting like ash tray, glove box, etc. But I will need to figure out which bulbs I will need and have them here before re-assembly.
  #358
Old 09-02-2025, 08:48 PM
I got mine from superbrite LED’s and they do not dim but they look great, remember the color spectrum of the LED also plays a role in how they look vs incandescent bulbs. It’s hard to see in the pics because I also have blue LED strips for mood lighting in the footwells. Pretty sure that I used these 4000k bulbs or something similar.
https://www.superbrightleds.com//194...-Natural~4000K
ID:	656563   Click image for larger version
1972 GTO
  #359
Old 09-02-2025, 10:06 PM
79 Phoenix's Avatar
Thanks! Cool looking dash and the instruments light up well. I'm going to mull this over and have to decide which route to goo soon, but this helps!
  #360
Old 09-03-2025, 05:59 AM
I took another look at the instruments this morning. Note that the illumination is slightly uneven. Also, I paid closer attention to the rheostat and noted that the result is 100%-85% then nothing: no very dim for those blacker than Hitler's heart nights.
The inside of the gauges are sprayed early 60's Pontiac engine blue. I will eventually dust this with gloss white
Name:	LED speedo.jpg
ID:	656565   Click image for larger version
Name:	LED gauge.jpg
