Old 09-08-2025, 09:30 PM
Held for Ransom's Avatar
I circled it...
So long, farewell.
  #42
Old 09-09-2025, 12:34 AM
unruhjonny's Avatar
maybe it was a light switch for those aftermarket gauges in the map pocket?
(if that’s what i’m seeing (flipped face down) in the console map pocket)
1970 Formula 400
  #43
Old 09-09-2025, 06:56 AM
Judge273's Avatar
Judge273 Judge273 is offline
There’s a good chance that the black tube with chrome tip is a light switch or dimmer for after market gauges.
I did disconnect and replace with map pocket. Only to find out the car went dead.
After pulling the starter and trying to find the fusible link. Only to reinstall the starter and gauges.
Kind of embarrassing but, lots of discovery.
Spent a few days under the car trying to find the electrical gremlins.
Mike/Illinois
  #44
Old 09-09-2025, 07:23 AM
Original starter!?
Hard to believe still has the original 350 starter.
  #45
Old 09-09-2025, 08:06 AM
Judge273's Avatar
The build sheet shows the starter to be “446”. This one is a 445. But, dates to car. Another mystery? Or just not correct…
Mike/Illinois
  #46
Old 09-09-2025, 08:19 AM
I think it is correct. The buildsheet probably shows the number for the starter/relay combination part number?
I show the 1108445 as for 1971 350 starter.
  #47
Old 09-09-2025, 08:31 AM
Judge273's Avatar
But, the car is a 400?
Mike/Illinois
  #48
Old 09-09-2025, 12:42 PM
Sorry, Mike. I thought it was a 350.
And yes the 446 is for a 400/455. (I had to look it up)
So not original.
  #49
Old 09-09-2025, 07:48 PM
unruhjonny's Avatar
i don’t see why that might not be original;
as i recall there have been several times in the past year when the “wrong” part was used at the factory;
the L30, L75, and L78 presumably could all use the same starter, as they all used the same style exhaust manifolds.
I cannot make out the manufacture date stamping… i’d think that might skew it as being original vs non-original…
1970 Formula 400
  #50
Old 09-09-2025, 08:59 PM
The date code that I can tell, is 1Axx which is Jan 1971. Not sure of day.
  #51
Old 09-10-2025, 08:55 AM
Judge273's Avatar
It’s a January 6, 1971 Starter. First Week of February on trim tag.
Mike/Illinois
The Following User Says Thank You to Judge273 For This Useful Post:
  #52
Old 09-10-2025, 09:58 AM
unruhjonny's Avatar
well i sure wouldn’t toss or change it;
not from a car that original.
1970 Formula 400
  #53
Old 09-11-2025, 03:40 PM
Ramairnacho Ramairnacho is offline
Default Starter
The starter in picture is a low torque starter I believe the 45 was low and housing smaller than the 46 high torque starter. If it's original I'm surprised it lasted this long.. I believe that all blocks look the same 350, 400, or 455 but different internal components making different compression. Maybe the didn't have anymore 46 starters and put a 45 in it. Either way it's a nice car and if I was replacing starter I would get a hi torque .
  #54
Old 09-11-2025, 04:40 PM
Judge273's Avatar
Making progress! Tuned up and battery topper and spring claps installed. Got rid of red cables.
Mike/Illinois
The Following 4 Users Say Thank You to Judge273 For This Useful Post:
  #55
Old 09-11-2025, 10:40 PM
I would have thought 400 with AC would bring the HD side post battery.
That's just thoughts , not facts.
Think it might be the first Fbody I have seen with Sienna interior.
It seems lighter than A-Body Sienna
Owner was definitely proud of the car to keep it so long .
  #56
Old 09-15-2025, 01:38 PM
Judge273's Avatar
Some more details.
Future tips.
Gauges replaced with map pocket
Sent from my iPad using Tapatalk
Mike/Illinois
The Following 3 Users Say Thank You to Judge273 For This Useful Post:
  #57
Old 09-15-2025, 04:14 PM
Transamric's Avatar
"We don't need no stinkin' gauges!!"
  #58
Old 09-15-2025, 05:08 PM
"gauges are for sissy's and worry warts"
(....2 weeks later blows head gaskets after alternator belt snaps on highway )
  #59
Old 09-18-2025, 10:04 AM
Judge273's Avatar
Got to have some gauges…
Super clean underneath with OEM exhaust
Mike/Illinois
  #60
Old 09-18-2025, 10:55 AM
Very nice!
I like the lower valence still has the black on it.
