Old 09-19-2025, 08:33 AM
Bill Eveland's Avatar
Default 55 Fiberglass front end
I had a fellow racer make these up for me, they will be put together for a 1 piece front end. Here is the 1st initial mock up. Look to take some decent weight off the gasser, the metal i took off was roughly 200 lbs, , I don't run the full lower bumper.
Another local guy will be making the front bumper ends and grill.
More of the front end is available upon request. Roughly 1500 plus shipping from TN. Hood and fenders
ID:	657418   Click image for larger version
ID:	657419   Click image for larger version
ID:	657420   Click image for larger version
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 09-19-2025, 08:42 AM
steve v's Avatar
steve v steve v is offline
That looks great! Any idea on the weight difference?
Old 09-19-2025, 09:00 AM
im guessing ill add back in at least 50-75 lbs going back in from the 200 i took off.
6.27@107
9.97@131
Old 11-17-2025, 09:06 PM
Front end is one piece now, still need to build an inner frame to tilt, will slide forward a bit as well .
6.27@107
9.97@131
Old 03-09-2026, 03:48 PM
Back together enough to make it flip, still have some bracing to do. also did some work to upgrade to a 525 box. and cleaned up firewall for a fresh coat of paint
ID:	666030   Click image for larger version
ID:	666031   Click image for larger version
ID:	666032   Click image for larger version
6.27@107
9.97@131
