Old 09-30-2025, 12:33 PM
steve's Avatar
steve steve is offline
Default 80-81 cars that used to be turbo. CROOKED SHAKER ?
My vin number says the car was an 81 turbo trans am from the factory. Someone put a 350 in it when the turbo died and tried to clone a formula. I now have a Pontiac 400 block in the car. See in the pic how far the shaker sits to one side? And that’s with the element mounted as far the other way it will go as well. I’ve seen a few pics online of cars with the shaker off by the same amount. Is it possible cars that were originally 301 turbo cars were set up a little different to cause this ?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 10-01-2025, 09:55 AM
78w72 78w72 is offline
301t cars & engine bays are the same as non 301t cars, same mounts & all. The crooked off center shakers are usually related to bent frames in the cross member area that allows the whole engine to sit to one side... not saying thats your issue but Ive seen it on quite a few cars over the years that werent 301t cars originally.
Old 10-01-2025, 09:58 AM
I put a Shaker hood on my 81 with a 400-it is centered
Old 10-01-2025, 09:01 PM
4dblnkldude's Avatar
Mine too!
Old 10-02-2025, 08:53 AM
steve's Avatar
I have paperwork from a frame/body shop stating the frame is not bent but I suppose anything can be possible. It’s just that it’s off by several inches and the body looks straight to the eye. Not to mention there should be other things off but nothing looks wrong. I would also think the nose would be farther off center than the cowl area and that doesn’t seem the case here as well.
Old 10-04-2025, 10:36 AM
Shoot some pictures of the Shaker base in the scoop, maybe one for a SBC?
Old 10-04-2025, 12:00 PM
Also what intake, carb & air cleaner base does the car have?
Old 10-04-2025, 01:49 PM
My 81 has a Performer intake a little low in rear but centered. My 78 has a T2 and is centered. So like he asked intake, base.
Old 10-07-2025, 09:25 AM
steve's Avatar
Sorry for the delay. Here are pics. The “carb stud” is 29.125” to the drivers fender edge and 28.00” from the passenger side. I guess the fenders are out of wack at least. Possible the whole front clip is pushed over but you can’t tell from looking at the outside of the car and my body panels are not off by that much. The intake is a Northwind. Holley terminator and gen IV
ID:	658344   Click image for larger version
ID:	658345   Click image for larger version
Old 10-07-2025, 09:53 AM
Im not familiar with the aftermarket drop base air cleaner set ups, or how the shaker plate is attached to it, maybe thats related?
But the front clip or subframe/core support can be off side to side, was that measured when put back together? Can measure it now to see if its off, subframe to rocker panels as well as an X measurement from top rear fender mount bolts to top core support fender bolts, should be equal.
Old 10-07-2025, 10:57 AM
burd's Avatar
burd burd is offline
If alls good, re rivet the base on
Southern Hamtramck Institute of Technology , Alumni
Put some 8” flakes and BFG’s on dude!, like everyone does🙄
Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers.
1978 YEE
1995 Q45
#whoremembers
