#41
Here's a thread that John V had about this tranny I think. ( the one you referred to I think)
1964 Build Sheet Codes
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
#42
Here's a sheet that I 'corrected'. Check if it is good?
#43
Looks good to me John.
Now need to update their table that lists all the option codes. Will have to go back over it , HD Fan is one that I know is missing. I think there are more also , HD Frame , HD Crossmember ... |
#44
Actually think this is correct, I was in a hurry and rewrote the close again on the '9' tranny.
![]() See if this is better.
#45
Wow you sure did.
Went right past me too. Here are the 6 and 8 tooth gears it's talking about on the output shaft of the trannys. John V. told me the secondary speedo gears on Fremont docs are installed on the production line. Not at the manufacturer . fwiw |
