Old 01-21-2026, 07:05 PM
scott70's Avatar
scott70 scott70 is offline
Default New cam
Got a new comp cam HR to replace the crower HFT I’ve been using. Engine guy questioned a couple of the rhoads vmax lifters,, nothing wiped but while we’re in there I don’t want any upcoming possible problems. Had Kauffman custom grind,, asked for their 236/242 cam but add 2 more degrees of exhaust duration for a 236/244 112 ls. On their site the 236 /242 cam has an advertised 290 but mine is 286 . Numbers wise I’m just a little bigger than the crower I’ve been using. Hopefully it works out good. 455 .040 over, 9.75-1, rare manifolds with their 3” headpipes. Stock , slightly reworked iron intake. TKX trans with 2.87 first gear and 3.31 rear. I use crower SS 1.60 enduro rockers.
Only 67 degrees of overlap?
ID:	663988   Click image for larger version
The Following User Says Thank You to scott70 For This Useful Post:
Old 01-21-2026, 07:19 PM
grivera's Avatar
grivera grivera is offline
Sounds like it will be an awesome combination. What does the “s” suffix in the grind/lobe number signify?
Will Rivera
Old 01-21-2026, 08:09 PM
scott70's Avatar
Heads are #64 and were cnc ported by sdperformance to 254cfm on the intake . Not sure about the "S". With the crower cam it made 491hp at 5200 /570 trq with 1 3/4 headers. Lost 15 hp with manifolds and mandrel bent 2.5" headpipes but now have rare oversized manifolds and their 3" headpipes.
The Following 2 Users Say Thank You to scott70 For This Useful Post:
Old 01-21-2026, 08:22 PM
grivera's Avatar
Nice - found this in the online catalog, page 5 but not sure what it means in a Pontiac application:
https://images.carid.com/comp-cams/i...ct-catalog.pdf
Will Rivera
Old 01-21-2026, 08:36 PM
scott70's Avatar
I guess Im missing something,,what the heck? Most of these rollers are on a B core. What is a S core? Will be using evolution lifters
Old 01-21-2026, 08:49 PM
AG's Avatar
AG AG is online now
What's the max lift your heads can accomodate?
Old 01-21-2026, 09:01 PM
scott70's Avatar
im not sure.
If this is not the cam I need I will send it back,get another one or whatever it takes. I was told to get a B suffix and I thought thats what i was getting. Not much on line about a S suffix but it looks like for a small block chevy,,,extreme 4x4 family or something like that. Whatever that means.
Old 01-21-2026, 09:50 PM
grivera's Avatar
May want to call KRE - with the number of cams they order I assume he knows what he’s doing but good to check.
Will Rivera
Old 01-21-2026, 10:42 PM
tom s tom s is offline
I think the Comp Catalog lists what the letters are.Tom
Old 01-21-2026, 11:29 PM
scott70's Avatar
All I could see was what he listed in response 4. Googling it all I could find was like one reference someone was asking about a S suffix. I should of just ordered their 236/242 HR cam. Ill call KRE tomorrow.
From random website++
Kind of strange…….
The “B” after the 3303 designates the master used was for a bigger base circle application.
Typically, on a SBC the suffix is an “S”.
This lobe is from the Extreme 4x4 family.
The exhaust lobe is from a family designed for use in LS1 applications.
Specs:
265/[email protected]
216/[email protected]
112 lsa
.316/.314 lobe lift
The A8054-13 is the serial number, with the -13 denoting the year it was done……. 2013.
Old 01-22-2026, 05:20 AM
scott70's Avatar
Anyone have a cam card for kre 236/242 hydraulic roller? Thanks
Old 01-22-2026, 07:17 AM
grivera's Avatar
Again from post 4
Will Rivera
Old 01-22-2026, 10:36 AM
We will often see a roller cam ordered with a "B" suffix code after the lobe number. With the code they can, but not always, alter the rated duration. Typically with 1-2 degree less duration.
The duration at .050" and .200" remain the same.
Also sometimes a "B' suffix code can, but not always, add an additional 0.001" to the lobe lift.
Different journal diameters can alter the rated duration.
Old information here:
Old 01-22-2026, 11:31 AM
grivera's Avatar
In the pic I posted (#4) it says if an S suffix is used in a BB Chevy application, the cam would grow approximately 2 degrees. I guess the question is does this mean the same thing in a Pontiac.
Will Rivera
Old 01-22-2026, 11:47 AM
Jay S's Avatar
Jay S Jay S is offline
That is annoying that KRE lists a marine XR profile on their site then sells a XFI. Evolution lifters should be up to that though, XFI’s nearly always work best with beehive springs.
I didn’t realize that XFI is what they sent you. All the HR cams I have seen that came from KRE are ground on using an “S”. If I remember right if it would be ground on a “B” the intensity goes from 50* to 49* with a “B”. Your better off with the “S” on that cam.
Old 01-22-2026, 11:57 AM
My specific explanation is what I've observed on roller cams ordered for a Pontiac application. Good examples are some, but not all, of Dave Bisschop's custom grinds. They are typically ordered with that code, and it doesn't matter if it's a Magnum Hyd lobe or a Xtreme Energy hyd lobe.
Example, here are numbers from a early Old Faithful cam as reported directly from a cam card:
Grind number P8 3122B / 3120B HR112.0
Rated 289 / 306 at .006" tappet lift
236 / 245 at .050"
112 LS / 108 ICL
Lobe lift .3800" and .3830"
Note the lobe numbers have the "B' suffix code.
Note the .006" numbers, 289 & 306, are slightly different than stated in the Comp Cams lobe section, they are 290 & 304
And another thing to understand often the duration numbers that show up on the cam card are ever so slightly different than what the catalog lobes show, as the Pontiac cams are typically ground on a slightly different base circle than the sbc/bbc typically use, and that can result in minor changes.
I can't comment on the S designation. I can say that Jeff K has specked two cams for me and he nailed it on both occasions. My first was a 232/238 also with XFI lobes. That cam made torque everywhere and carried power right to where you'd want to shift at 5500 or just there after.
My current cam uses QNI lobes.
I will say however, the XFI lobes and the lifters I had on them (pre-updated Morels) was a very noisy combination. The current cam with Q lobes and Johnson short travel lifters is nearly silent.
-Jason
1969 Pontiac Firebird
Old 01-22-2026, 02:24 PM
scott70's Avatar
Bullet has a 4/7swap 236/244 @ .050. Intake lobe HR290/3625,,,,exhaust HR301/3595.
112+4.
Im not blaming anybody for the confusion on the cam,,,just wish i had known. Not that I know what Im talking about. Im sure it would be fine just not what I was hoping for.
Old 01-22-2026, 03:08 PM
zippy's Avatar
zippy zippy is offline
Scott, This cam is a little bigger than RAIV right? Deffinately interested on how it performs. I have the same combo 455. .040 over, 4.45 stroke, SD ported #64 heads. So hard to find people using #64 heads LOL I have the FT RAIV in mine with Crower Cam saver lifters. 1.65 rockers. TH400/3400 stall tho and 3.08 rear.
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 01-22-2026, 03:11 PM
Scott,my catalog has a number listed for the type of cam cores.Tom
