73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 01-25-2026, 12:29 AM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Wiggling steering column
My steering wheel column on my 77 lemans is very wiggly. I'm going to have the steering wheel off to change the key, and I was just wondering which bushing could be causing this. The tilt is locked and it still rocks. Thanks Andrew
Old 01-25-2026, 11:04 AM
4dblnkldude's Avatar
The 4 bolts deep in the column are probably loose. You have to go deeper than just the key. A little time consuming but easy just sitting in the driver seat.
Old 01-25-2026, 02:31 PM
OG68 OG68 is offline
x2.
My 70 El Camino and 77 Chevy pickup both had that problem.
Open up the column and tighten the screws.
Old 01-25-2026, 03:14 PM
I agree and I always use red loctite on the 4 little screws
Old 01-26-2026, 04:56 PM
You mean for the turn single switch? All I need to do is get the lock plate off and I'm in there. What else needs to be done? I figured I get this done while replacing the key.
Also any good hints on how to get the snap ring to the lock plate off i have the tool that compresses the plate.
Old 01-26-2026, 05:59 PM
Long thin blade screwdriver for the snap ring. Pry up between ring and column housing.
You need to pull the signal switch up and out of the way to access the four hex headed screws that hold the bearing housing.
Old 01-26-2026, 06:05 PM
Okay I'll definitely take a look when I get the lock plate off
Old 01-27-2026, 06:37 AM
No I meant the 4 screws that hold the bearing housing, There is a cheap lock plate removal tool available that pushes down the lock plate make it easier to remove the snap ring ( or C-clip ) it also makes it easier to reinstall.
https://www.summitracing.com/parts/wmr-w80649
I have a couple of them and they do make the job easier. But not absolutely needed.
Old 01-27-2026, 04:55 PM
So I was working on the car today got everything all torn apart helps to have the little plastic shield off before trying to dig at the snap ring. Got down to the ignition, and tried tighten the bolts. All of them were tight? What would you recommend.?
Old 01-28-2026, 02:16 AM
Sorry ment screws I'm going to throw everything back together except for putting in the lock plate. An look into fixing it later.
Old 01-28-2026, 05:03 PM
Update she needs a column simple as that
