Old 01-25-2026, 07:16 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
Default 67 Firebird Tail Panel Install
I probably shouldn’t be trying to install the Tail Panel, but I figured Id give it a shot. I have the gaps closed up pretty good but the passenger side has a big ugly gap and I’m not sure how to close it up anymore.
Driver side could use a little more but I could live with it the way it sits now.
Can anyone give me any tips on how to get the gaps closed up more. The body lines look lined up correctly so pushing the tail panel higher into the corner may mess with the body lines.
Anyways, has anyone had to deal with this? Have any tips!
Thanks for any help.
Ozzy.
ID:	664187   Click image for larger version
ID:	664188   Click image for larger version
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 01-26-2026, 11:07 AM
Tempest's Avatar
Tempest Tempest is offline
Have you watched this guy?
https://www.youtube.com/watch?v=4ZANCfoqY3s
Old 01-26-2026, 01:40 PM
Yes I love that guy. Unfortunately he had new quarter panels so I’m guessing the panels line up a lot better.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 01-26-2026, 05:28 PM
rohrt rohrt is offline
How does the trunk gaps look? Does the 1/4 need to come in any more?
Old 01-26-2026, 11:57 PM
Trunk gaps are roughly 1/4” all the way around.
I was messing around with it today. Squeezing the quarter panels with a ratchet strap and I got the passenger corner really close but there was so much tension. If I tack welded the flanges I’m sure it would not hold it.
After adding the ratchet straps and squeezing them together, the gap on the passenger side changed to about 3/16” and the driver side stayed at 1/4”.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
