Old 03-15-2026, 12:47 PM
moneypit's Avatar
moneypit moneypit is online now
Default Late model bathtub installation trouble
The alternator hits the intake overhang. Are there any specific accessory brackets that need to be used?
ID:	666309   Click image for larger version
ID:	666310   Click image for larger version
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
Old 03-15-2026, 01:50 PM
JLMounce JLMounce is offline
A first gen Firebird bracket may work with a slightly longer belt. The firebird bracket has the ability to move the alternator closer to the driver side fender, away from the intake casting.
-Jason
1969 Pontiac Firebird
Old 03-15-2026, 02:22 PM
moneypit's Avatar
Thanks for the reply. Isn't the early Firebird a two piece bracket with one going from w/p to alt and the other from t-stat to alt? I guess I could try to fabricate something for the rear mount. I'm having evil thoughts about just separating the water crossover and calling it done. Although cutting up a nice $2500 intake was not the plan.
71 GTO base 400 A/T
Old 03-15-2026, 02:48 PM
johnta1 johnta1 is online now
It just needs to be up a little bit to make it work?
(rotated to driver side)
I'd cut that slotted piece off and add a section of metal to extend the curve more. (up)
If it needs more than a little, possibly try an extension bracket/piece on the bottom hole mount to rotate the bottom up?
(swivel the bottom of alternator up)
Old 03-15-2026, 03:35 PM
moneypit's Avatar
That's a good idea, thanks. I think the bottom "pivot" will be okay, just need to extend the slotted piece about 6 inches. Gotta love old hot rods!
71 GTO base 400 A/T
Old 03-15-2026, 04:00 PM
tom s tom s is offline
This is the first issue that has been brought up to us.Will let John know.
Old 03-15-2026, 04:04 PM
Besides that issue it looks like that fan is so close to the radiator that it’s blocking off 60% of the total rad area .
Old 03-15-2026, 05:46 PM
moneypit's Avatar
Cooling Components CCI-1730
I've got about 1 1/4" clearance between the water pump and fan motor.
Not much room in a 37.
71 GTO base 400 A/T
Old 03-16-2026, 09:55 AM
Technically speaking, yes it's 2 pieces. However I've run only the arm from the water pump for over a decade with no issues.
-Jason
Old 03-16-2026, 10:30 AM
gtohunter's Avatar
gtohunter gtohunter is offline
https://www.zrd.com/pd/esdtbadj.html
Jimmy M
68 GTO
The Following User Says Thank You to gtohunter For This Useful Post:
Old 03-16-2026, 11:16 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Originally Posted by gtohunter View Post
This is a good suggestion. You could run it in between your alternator and A/C pump (assuming they share the same belt). It can be difficult to get a straight shot with a rod linkage. You can make an extension bracket to come up from the water pump if necessary.
Old 03-16-2026, 12:19 PM
sdbob sdbob is offline
Talking
Funny. I read late model bathtub(figuring home bathtub) install what's that doing in street! I havent got to mine yet, now I'm a where. I'll need to pull all my brackets out.
Old 03-16-2026, 01:03 PM
Tandyman Tandyman is offline
Mp , this is a simple bracket I made up for my 69 firebird. Very stiff even compared to the original. PITA 2 piece .Maybe something similar will solve your problem. And the turnbuckles are dirt cheap on Amazon
Glenn
The Following User Says Thank You to Tandyman For This Useful Post:
Old 03-17-2026, 02:14 PM
Dragncar Dragncar is offline
300$ turnbuckle ?
I could make it myself for a 3rd the price or less. MSRP of 400 $............. nuts.
Old 03-17-2026, 04:24 PM
ANDYA ANDYA is offline
Agree with JLMounce. The alternator brackets for a 67 Firebird are long and puts the alternator in front of the valve cover. Depending on your pulleys you would have to get the alternator to line up or you would need pulleys to line up with the alternator. Depending on the diameter of your pulleys you would have to find a correct length belt.
Old 03-17-2026, 07:03 PM
AG's Avatar
AG AG is offline
Just grind the intake to get the clearance.
Old 03-17-2026, 08:25 PM
moneypit's Avatar
Thanks for all the suggestions! I will post a picture when I get it back on the road.
71 GTO base 400 A/T
