Old 01-03-2026, 09:35 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Default Header fitment for a 69 Firebird
I am thinking of getting headers for my Firebird . I am looking for recommendations on ones that fit well without having to beat and bend them to fit.
The Following User Says Thank You to Rob in NH For This Useful Post:
Old 01-04-2026, 03:38 AM
gobrdgo gobrdgo is offline
Doug’s headers.
The Following User Says Thank You to gobrdgo For This Useful Post:
Old 01-05-2026, 11:54 AM
JLMounce JLMounce is offline
Second on the Dougs headers. They fit nicely up against the floor boards and don't impact ground clearance.
On my car I did have to make a dent in the driver side forward tube to clear the zirk fitting on the inner tie rod as it was contacting the tube. My car is very low however and that may not happen on a stock height car.
A standard sized filter will not fit however. You'll either need to use a smaller filter and increase your oil change frequency or run a remote mount filter.
-Jason
1969 Pontiac Firebird
Old 01-05-2026, 01:27 PM
65madgoat's Avatar
Biggest issue with any headers and a first gen is fitment next to the steering box. Never good. If you have larger tubes because you make 575+hp it gets even closer and if you use a new Borgeson box they will for sure hit that slightly larger box.
Unless over 500hp or so just go with ram air manifolds honestly. Won't notice anything other than sound really.
Old 01-30-2026, 09:22 PM
69FIREBIRD76MM's Avatar
Hedmans D port #35270 fit perfect, Doug's if you are running round Port heads.
Old 01-30-2026, 09:23 PM
Default Headers
I recommend hedmans #35270 fit perfect n don't hang low, stay away from hooker's
Old 02-17-2026, 09:27 PM
Sport69 Sport69 is offline
Why don't you get the stock headers (Long Branch Manifolds) for it?
Don't forget you'll need the oil filter housing adaptor no matter what, plus I would go with a RobbMc. starter, it has an aluminum casing for heat dissipation and it's adjustable so you can move it away from the header.
I've run Long Branches with a RobbMc on my Ram Air III 400 since completing it in 2014, I've never had a heat sink starter problem or an exhaust leak.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 03-17-2026, 02:04 PM
So, Rob, what did you decide?
Old 03-17-2026, 05:57 PM
tom s tom s is offline
Best headers I have ever had on my 69 bird were custom built on the car.4 speed car,EVERYTHING fit like it should.Not for the weak of wallet!Tom
Old 03-18-2026, 12:59 PM
Lee's Avatar
Lee Lee is offline
Here is a video of me installing a set of Doug's D569 D-port headers in a '68 Firebird. I made some mods, that I show in the video, to make it a rather easy install.
https://youtu.be/EXBkWpQJJJU
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 03-18-2026, 03:41 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Does not help OP much these days, but my vintage 1 7/8 x 3.5" long tube equal length D-Port headers by "Headers by Ed" fit like a glove.
As Tom stated, custom frequently is king. Both in fit and price!
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 03-24-2026, 01:53 AM
Squidward's Avatar
I used Hedmans on my 67. I got a set with the ball/cone collector. 35270 looks like what I have. Decent fit.
I did have to do a little hammering for oil filter clearance. And it definitely required a curved Pontiac pitman arm.
Old 05-01-2026, 10:24 PM
Rob in NH's Avatar
I haven't ordered anything yet, I've decided on another engine instead. i
Old 07-04-2026, 10:46 PM
Rob in NH's Avatar
Has anyone heard anything about patriot headers, they are part of pertronics/ Dougs headers group. and was wondering if anyone here has used that brand.
Old 07-05-2026, 07:11 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
i have a set of dougs dports on a 68 four speed in rhode isalnd. they fit very nice.
i also picked up a set of 25 yr old hooker supercomps from a guy with a 68 firebird convertible last summer. they are in very good shape if your interested.
Old 07-11-2026, 02:27 PM
Rob in NH's Avatar
is there a part number for it?
Old 07-11-2026, 06:21 PM
3X24SPD 3X24SPD is offline
Default Headers
Hi Rob,
I have a set of first gen firebird headers that I bought cheap at Stafford Springs Swap last year. I'm not going to use them for anything.
I bought them cheap because I wanted to try them out and see if they fit my 63 Tempest- but they didn't.
I'm in Brentwood- so close by & if you're interested I'll let you have them cheap.
Here's a pic of them.
-Bill
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
The Following User Says Thank You to 3X24SPD For This Useful Post:
