Old 04-02-2026, 08:40 PM
zippy's Avatar
zippy zippy is offline
Default Switch pitch pump stator shaft
Just got another th400 to replace my ailing one. BOP cases are hens teeth in Canada. So, I go get this core. $400canuck bucks. It has dual terminals on plug, like my present switch pitch. Mine never worked and I busted input shaft. So swapped regular pump/stator shaft and 3600 stall heavy fluid spinny bit.
Now this trans has a 13" sp converter. The dual bushings inside throat before splines
But pump has no journal with feed hole.
Question is, anyone make them anymore or is used only option?
I not total sure I wana go sp. it would be cool. 18yeaes ago? Trans builder couldn't get mine to work, so I just busted the input shaft on hard shift and moved on. Doing full manual shift kit etc etc
Is it even something I should worry about trying to get parts and make sp work? 77 TA with 455HO punched to 470. 3.08 rears. Highway town don't drag race anymore. But spirited driving always
Dan Pesonen
"If it ain't broke, modify somethin till it is"
The Following User Says Thank You to zippy For This Useful Post:
Old 04-02-2026, 08:59 PM
I had a switch pitch converter until I went to over drive. My car weighed 3725 lbs with me and a quarter tank of gas. It made 586 engine hp. The trans was built locally and I never had any problem with it. If you can get yours to work I would highly recommend it.
Old 04-02-2026, 09:12 PM
zippy's Avatar
Well I wanted od. Just not in the finances. Present 400 has lost 2nd. Most likely the sprag so I wanted a spare anyways
Dan Pesonen
Old 04-02-2026, 09:37 PM
433lemans's Avatar
433lemans 433lemans is offline
Contact Jim Wiese at Tri-Shield Performance. Switch pitch pro.
www.trishieldperformance.com
Old 04-03-2026, 08:11 AM
PAUL K's Avatar
PAUL K PAUL K is offline
There's a trans shop in Elk Grove Illinois that modifies standard shafts to work for switch pitch applications. He sells them on eBay along with a bunch of other transmission parts.
Go fast, see Elvis!
Old 04-03-2026, 08:23 AM
I gots a Sw-P 400 with 12" converter sitting (was in my 68), and may have a spare front-pump+ FWD Pack. Shipping is the only grief.
Sw-P is a nice setup for highway gears in the heavy car. Pull-away TQ & Passing power are the deal.
Old 04-05-2026, 04:38 PM
Schurkey Schurkey is offline
Bruce Roe sells--or used to sell--an electronic controller for switch-pitch transmissions. IF (big IF) they're still available, I strongly suggest you get one. They provided MUCH more control over the stator than the OEM switch. I bought mine ages ago, for the switch-pitch TH425 in a Toronado.
The last contact info I had for Bruce was [email protected]
