Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 04-21-2026, 02:16 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Default Got my 66-67 Rally Cluster Adapter Harness in record time - but
... no instructions or wiring diagram.
For most of the group, this would probably not be an issue, but, I could short out an electric toothbrush with no problems. Considering how much I have invested in finding clusters, parting a good one together and then getting it restored, I'd lose my mind if I inadvertently screwed this up.
What is the best form of contact to get a response? I've emailed Ames before to no avail using the contact form. I get it, everyone is short staffed anymore but I feel like I'm on the cusp of finally making some progress.
Thanks!
The Following User Says Thank You to Ragtop Man For This Useful Post:
Old 04-21-2026, 06:32 PM
Peter Serio's Avatar
Default 65 GTO dash wiring
Here is a drawing I made years ago, it could be of some help.
The adapter harness is a actually a copy of a 1965 Lemans-GTO part only. They do sell it new and I guess they say it can work for other years.
For true rally gauges in a GTO for years: 1966 and 1967 (GTO) the entire dash harness including the fuse block was unique to either with or w/o gauges.
Name:	65 GTO rally gauges-Wiring=my drawing from 1989.jpeg
ID:	668609   Click image for larger version
Name:	65 GTO dash wiring_LH side of page.jpg
ID:	668610   Click image for larger version
Name:	65 GTO dash wiring_RH side of page.jpg
Peter Serio
Owner, Precision Pontiac
The Following User Says Thank You to Peter Serio For This Useful Post:
Old 04-22-2026, 10:16 AM
Ragtop Man's Avatar
Thank you - I was trying not to tear out the old harness and fuse panel, the adapter harness seems like a fairly easy workaround.
When the car gets back, and I have the cluster in front of me, then I think answer should be pretty clear.
Old 04-22-2026, 02:33 PM
That adapter will work on a 66 or a 67 GTO as long as your present non-gauge wiring & fuse block are both in good condition.
Peter Serio
Old 05-06-2026, 08:09 AM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Thanks!
Ragtop Man, I'm sorry for this falling through the cracks!
If you still need any assistance, please email me directly at [email protected].
Thanks!
Kyler @ Ames
[/SIGPIC]
Smilies are Off
