Old 05-03-2026, 09:29 PM
JOHNNYGOAT's Avatar
JOHNNYGOAT JOHNNYGOAT is offline
Default Motor mounts
Can somebody tell what these motor mounts fit and can I use them to install a 455 in my 70 Formula. These came in a box of parts that came with the car. Thanks
ID:	669441   Click image for larger version
ID:	669442   Click image for larger version
ID:	669443   Click image for larger version
ID:	669444   Click image for larger version
71 GTO Convertible 455HO AT Canyon Copper
Old 05-03-2026, 09:33 PM
Hard to tell what body style they came from, there should be a code stamped into them, Those later style mounts came in B-A-F, and G body styles that all differ slightly in hieght.
If they are F-body mounts they should work on your Formula with the correct style captured frame mounts.
Old 05-04-2026, 12:09 AM
Schurkey Schurkey is offline
^^^ Yup.
There's AT LEAST two different styles. He says there's several different styles, and I can't contradict that.. What I know from experience is that the Fullsize mounts are taller than the F-body mounts. I found that out the hard way.
Old 05-05-2026, 10:19 AM
70-74 f-body don’t use that style mount.
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 05-06-2026, 09:51 AM
78w72 78w72 is offline
There should be part #'s stamped on them that will identify what they are from... i started a thread not too long ago that someone posted some numbers. Google should help too.
Edit- https://forums.maxperformanceinc.com...d.php?t=882596
Old 05-06-2026, 11:41 AM
72projectbird's Avatar
You can use them, just order the correct frame side mounts to pair them with. 70s have steel clam shell style frame mounts, later cars have a steel and rubber combo mount.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-07-2026, 11:15 AM
They look too tall for Firebird. They look like "B" body mounts.
Old 05-10-2026, 07:12 PM
JOHNNYGOAT's Avatar
OK so we are saying these are not correct for 70 Firebird Formula . I media blasted them and can not find any numbers. Sorry guys but this will be my first time installing a motor.
Old 05-10-2026, 07:45 PM
Default The metal mounts that bolt to the engine are NOT compatible with those frame mounts.
You need a pair of the 1970 rubber & steel motor mounts.
Part numbers are 2335 and 2336.
They bolt to the engine block and sit down over that frame mount.
Then a long bolt goes through the motor mount AND the frame mount (both) from front to back.
Old 05-11-2026, 10:47 PM
chuckies76ta's Avatar
My understanding. Here are the frame mounts used. https://butlerperformance.com/i-3164...tegory:1393553
Here are the engine mounts: https://butlerperformance.com/i-2445...tegory:1393553
This is what my 72 Firebird has.
My 76 Trans am has those other ones pictures above. With the clam shell frame mounts. https://butlerperformance.com/i-3016...tegory:1393551
950 Quickfuel.
