Old 06-05-2026, 07:31 PM
70ram4 70ram4 is offline
Default Paint removal on plastic shroud
Hi guys my 70 has a good fan shroud, unfortunatly it has some high glass black paint overspray on it. Is there a way to remove this an still keep an oem matte finish on it and not destroying the shroud? ? or am I just out of luck? The shroud is plastic or whatever the oem was. Thanks
Old 06-05-2026, 10:52 PM
JSuchma JSuchma is offline
Commercial paint stripper might be too harsh on the plastic shroud. Try some spray-foam oven cleaner on a small, hidden area first. Should wrinkle the paint after a few minutes and wash off with a hand-held sprayer on a garden hose. Good luck!
The Following User Says Thank You to JSuchma For This Useful Post:
Old 06-05-2026, 11:21 PM
rwfisher's Avatar
rwfisher rwfisher is offline
I’ve used purple power as well as Citristrip (comes in plastic bottle) without damage on plastics. Try in a spot hard to see.
Old 06-06-2026, 07:57 AM
great ideas , thanks
Old 06-06-2026, 11:35 AM
rdk rdk is offline
brake fluid, I have used it to remove paint from interior panels with no problems
Old 06-06-2026, 10:10 PM
SRGN SRGN is offline
I've used laquer thinner or enamel reducer, try it on a hidden area first to make sure it doesn't change the finish too much. I've also used brake cleaner on a rag as it's not as "strong" as the other solvents.
Old 06-08-2026, 06:59 PM
Brake cleadner, never tried it, but worth a shot.
Old 06-09-2026, 12:16 PM
I can tell you the original plastic wheel well spoilers on a 78 TA do NOT like paint stripper!
Old 06-09-2026, 01:51 PM
Cammer-6 Cammer-6 is offline
perhaps a chemical stripper made for boats and vettes?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
