Old 06-28-2026, 03:28 PM
1911a1 1911a1 is offline
Default Weight of a 15” Honeycomb wheel?
I was curious if anyone happens to know or has weighed a factory 15” honeycomb wheel?
One of mine is off now but of course it has a tire on it. It seems mighty heavy to me.
Wondering the difference in weight between a factory and aftermarket 17” cast aluminum wheel.
P.S. don’t have the scratch for the billet honeycombs I found on line.
Old 06-28-2026, 04:12 PM
Nobuddy Nobuddy is offline
I have an original 15x8 setting here to get tires tomorrow. 19.2lbs.
So many and much better tires available for the 17 but it might not be lighter.
Old 06-29-2026, 01:59 PM
The 15x7 Honeycombs w factory trim ring & center cap weigh right around 30 lbs. Will post back w an exact to the ounce weight.
The only thing heavier that I've ever pulled and shipped in a factory GM performance 15x7 steel wheel are the '86-87 Grand National wheels.
Chrome with black accents, they come in right under 32 lbs.
For comparison, late '60's, early '70's 14x6 GM A-body steel wheels typically come in around 18-19 lbs.
Have a list at home of exact weights, numerous sizes, some weights also with mounted G70-14's. F60-15's, and G60-15s.
Old 06-29-2026, 05:36 PM
Sorry - This registered as snowflake not honeycomb which I suppose is obvious from the 15x8. So lease ignore post #.2
Barry
