Old 07-08-2026, 09:16 PM
lintmann lintmann is offline
Default Trunk Spatter Paint???
Does anyone have a first hand recommendation for a black/aqua spatter paint that is like the original??? Something close to my pic would be great.
I'd prefer to stay away from rattle cans if possible.
Name:	Spatter Paint.jpg
Old 07-08-2026, 10:05 PM
rwfisher's Avatar
rwfisher rwfisher is offline
I know you indicated no aerosol but you may want to check these out anyway. I’ve had great luck with them and the folks there are very helpful. These also aren’t affected by moisture like many others..
https://www.thorntonmusclecars.com/p...ge/guru-colors
Old 07-08-2026, 10:38 PM
OG68 OG68 is offline
X2 for Thorton
Old 07-08-2026, 11:17 PM
70GS455 70GS455 is offline
Zolatone made the original paint. They ceased operations but there are similar products:
https://tcpglobal.com/collections/sp...zol-30-ts02-qt
Old 07-08-2026, 11:19 PM
https://www.thepartsplaceinc.com/pro...ne-quart/40036
Old 07-09-2026, 12:58 PM
Thanks guys, Thorton would be the perfect match but unfortunately they show out of stock.
70GS455, have you personally seen those products once sprayed? I can probably order in the one from The Parts Source so if it's like the image I posted I'll go with them.
Old 07-11-2026, 06:12 PM
Has anyone used this from OER?
https://www.summitracing.com/dom/par...illocation=dom
It also comes in a can too.
https://www.musclecarsandclassics.ca...Pc8V3qjEfx8Pyn
This too that 70GS455 mentioned. I'm just not sure if he has actually used and can vouch for it.
https://www.thepartsplaceinc.com/pro...ne-quart/40022
These two products seem to be what is available so can someone let me know if they have used either one and were happy or not with the product I'd really be happy to hear your thoughts. Thanks
Old 07-12-2026, 12:29 AM
Yes (sort of), I have the original Zolatone in my trunk. Looks factory
Old 07-12-2026, 01:15 PM
Oldskol65 Oldskol65 is online now
Finished 65 trunk (5 days ago) with Z-tone. Did base coat with black flattened epoxy primer. Sprayed zoletone spatter paint (this one from parts place) with 2.2 size tip. Would have used larger if I had available. Combined with z tone quick step catalyst at 16:1 (used 2oz for 1 qt RTS) Pleased with results and durability...so far. Scrubbed with wet cloth: no color transfer. With lacquer thinner: very small transfer of black (could have been from primer?) Z-tone and quick step catalyst from TCP...will use on next one. Click image for larger version
Name:	Black Epoxy.jpg
The Following 2 Users Say Thank You to Oldskol65 For This Useful Post:
Old 07-14-2026, 11:17 AM
Where was your car built? The Fremont built cars had a very different texture to the trunk spatter.
Old 07-16-2026, 10:13 PM
This an Oshawa car, the pic that I posted is from the actual car.
