Old 01-20-2004, 07:31 PM
forsakenfew forsakenfew is offline
is this a direct bolt in or am i gonna have to do some fabrication? are the tranny mounts the same? am i going to have drive shaft issues?
Old 01-20-2004, 08:03 PM
This is not a direct bolt in but you should not have major problems as long as your 1964 combo is complete.
Old 01-20-2004, 09:00 PM
thanks for the reply bob. could you give me any more info as to why this is not a direct drop in? what will i need to do?
thanks in advance
Old 01-20-2004, 09:02 PM
60man's Avatar
60man 60man is offline
forsakenfew:You didn't mention what the 64 trans was. If it is a 4 speed hydamatic it should be almost a direct bolt in. I am not sure a "slim jim" would be a direct bolt in. All 60's used the 4 speed where as some 61-64 used the slim jims. I think the slim jims are longer than 4 speed hydro.
Outlaw Pontiac Racers Association"For Those Who Live The Legend"
Do it now fool! Life is short.
60 Ventura 4300# 12.38 @ 108.10 / 1.66 60'
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 01-20-2004, 09:07 PM
60man's Avatar
Forgot to mention if lenght of drive shaft is a problem,just have it shortened. I had to shorten mine to use with a TH400 in my 60 Ventura. With the two piece drive shaft on the 60's you must maintain alignment as per shop manual. Very important with two piece shaft !!!
ECM member.
MANDRA
