Old 08-25-2003, 02:35 PM
medic medic is offline
How do you tell which is which?
Old 08-25-2003, 02:47 PM
The 3 tab pan will have 2 slots and a hole for the rear rubber gasket.
The 5 has 5 slots for the gasket.
johnta1
Old 08-25-2003, 03:06 PM
OK but where are the slots and the hole located? is it on the rear of the pan and are there slots and hols in the pan itself?
Old 08-25-2003, 03:20 PM
The rear of the pan rail that bolts to the block.Looks like a u-shape.
johnta1
Old 08-25-2003, 03:50 PM
Ok still not to clear on this, I think we are talking about the area where i used a cork gasket. goes around the rear main cap, correct. I did have a rubber gasket with a couple of triangles on it but when I asked a question about using it no one answered. should I have used the rubber one also?
Old 08-25-2003, 06:27 PM
WARPed's Avatar
WARPed WARPed is offline
No, believe it or not you did the right thing using the cork one. If your rear main cap has a grove to accept the cork gasket then you definitely do not want to use the rubber one.
with out questions there can be no answers
1969 Grand Prix
[email protected](1.358)
[email protected](1.342)
WARPed Tepee Forums
[email protected]
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 08-25-2003, 06:58 PM
Thanks warped
