Old 09-12-2004, 04:57 AM
Hawk397 Hawk397 is offline
Send a message via AIM to Hawk397
Anyone do this or look into it? Looking at any feasibility, info, etc.
Thanks!
Mark
71 Firebird Custom - Fuel Injected & Over-drived!
Old 09-14-2004, 11:52 PM
Young One79TA Young One79TA is offline
Cool! Nice to know that it will fit as I will be buying one as well.
Old 10-22-2004, 06:00 PM
shotgun shotgun is offline
PY Staff -Tech
I am reviving this because I am about to order a Vintage Air System for a 71 TA.Not sure which one to get.How did you guys make out? Any pictures? Thanks
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 09-15-2004, 04:52 AM
Hi Trev:
So it can be done!! Yea, I figured out yesterday that I'd loose the glove-box! I know I'm not going to get a real feel for it until I have the actual unit.
Mark
Old 09-26-2004, 09:46 AM
Brock, I made a block off plate out of a piece of sheet metal. Used stock holes and body sealer.
I'll be doing this in about a month, we'll see how it goes!
My current issue revolves around the fresh air cowl inlet. Since the Vintage Air doesn't use outside air, I'd like to seal it off. Now, if I seal it off, it looks like I could "modify" the interior to give me a little more top and back room. (It's the area just above where the arrow on the box is in my pic) Just not sure about starting to cutup sheet metal at this point though!
Old 09-15-2004, 06:58 AM
Trev Trev is offline
Mark,
When you speak to the reps from either Vintage or Classic, they recommend their 'Super Cooler' packages, but I was thinking about the compact unit also. I would be interested in your findings if you go that way.
Old 10-23-2004, 05:43 AM
Check my topic further down in this forum. There are a couple of installation pics there.
Old 09-25-2004, 09:01 PM
bbutler bbutler is offline
Me too! I have to put AC in a non-ac 73 TA. What do you do about the firewall after you rip out the heater?
Brock
73 Trans Am
71 Porsche 911T Targa
68 Alfa Spider
76 BMW R90S
75 Yamaha XS650B
Old 09-14-2004, 04:08 PM
Ok, so I fabbed up a card-board box the size of the Gen II Compac (20.5" long x 9" high and 7.75" deep) I'm not very optimistic. Leaving room for the hoses on the passenger side, this is my best guess. Another thing for anyone that's done this. The 9" high clearance is the actual size, how much room do you need on top of that to route the ducts - I have none!
Opinions welcome!
Mark
Old 09-26-2004, 01:28 PM
Mark, I plan to combine the Vintage air unit, which only recirculates interior air, with a pair of non A/C kick panels. I can disable the top pull cable on each side, as the top ducts will be used for A/C, and still use the bottom duct to bring in some fresh air as desired. Best of both worlds I think.
Old 10-23-2004, 05:40 AM
I bought a Vintage Air Universal Compact system. I have done a rough mount of the unit under the dash, but will not progress further until the car comes back from paint (about a month I hope). I just read on another post that Vintage sells a bracket for the Pontiac Engine. They did not even offer this to me???
Thanks!
Mark
Old 10-23-2004, 06:33 AM
PY Staff -Tech
I did see the other post.I was hoping for some more up to date pictures so get to work!!
Mounting the compressor is not an issue for me,we used a complete billet serp belt set up from March.
I am trying to put 10 lbs of potatoes in a 5 lb bag.Besides the a/c and all the stock stuff also need space for 2 computers for the fuel injections and nitrous controllers.
Oh and the driver is 6'5" and the car will be lowered 3" so I am cutting the floor up to run 3" exhaust. In my case a 1/4" matters.
Old 09-14-2004, 08:51 PM
I am getting ready to order a system myself for my 79 body. The only thing I can say in response to your mock up, is that the actual unit is not a rectangular box, so you have more room than you think. I did install a vintage air system in a 79 about 6 years ago. The thing did fit under the dash, and the ducts were very flexible.Unfortunately, I did not take any pictures. Glove box is a right off!
Old 10-23-2004, 05:58 PM
jdcoic jdcoic is offline
Here is an install write up w/pictures of a Vintage Air Gen II compact system in a '70 camaro, (same basic bodystyle/dimensions)
http://carbuff.homeip.net/ac.html
When I ordered a universal heater w/defrost kit (pics: http://www.coicfamily.us/projects.html) from vintage air, I inquired about A/C for my car, and they did tell me that they not only had the compressor, but brackets as well made just for my car/engine.
Hope this helps - Josh
