Old 07-03-2005, 10:14 PM
bukey's Avatar
bukey bukey is offline
got a 65 gto with a 68 motor im building.its got a 4 speed trans.i want a loppy cam what do you suggest.i have a crane powermax from a prior rebuild.grind #h-272-2 replaces hmv-272-2.part#283941 remember something loppyi drive like a grand ma
64 Gto
65 Gto
68 Gto
64 Corvette
67 SS 396 camaro
76 BMW 2002
05 Silverado 3500
09 G8 GT
Old 07-03-2005, 10:15 PM
Thunderskull Thunderskull is offline
Send a message via MSN to Thunderskull
What's your displacement and your approx compression?
Old 07-03-2005, 10:32 PM
bukey's Avatar
400 30 over.16 heads just redone by a machine shop.standard crank.compresion prob.10-1.
64 Gto
65 Gto
68 Gto
64 Corvette
67 SS 396 camaro
76 BMW 2002
05 Silverado 3500
09 G8 GT
Old 07-04-2005, 04:43 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Crower makes a 228/235/112 cam, pretty sure the number is 60243. We've used a few of them in early 400's with manual transmissions. Pretty aggressive cam, at best 12" of vacuum at 1000rpm's, noticable lope at idle. On KRE's dyno they made 424hp/465tq with a 406 engine using unported 72cc heads, iron intake and q-jet.....Cliff
Old 07-04-2005, 11:03 AM
bukey's Avatar
thanx cliff by the way the carb for my 68 gto runs like it never has.it will fry the tires off .couldnt be more impressed with your work.back to the cam,the one i allready have is a crane.it says 272/284 adv. duration.cam timing,216/228 duration.lift,454/480.will this be a close match to your suggestions?
64 Gto
65 Gto
68 Gto
64 Corvette
67 SS 396 camaro
76 BMW 2002
05 Silverado 3500
09 G8 GT
Old 07-04-2005, 11:10 AM
Cliff R's Avatar
Great, glad you like it!
The 216/228 cam will act much like a stock cam in the 10 to 1 CR 400 engine. Probably idle smooth with a "deep/heavy" sound. The 228/235 cam would be a much better choice as it will bleed off some cylinder pressure at low speeds and pull very strong in the upper mid-range and top end. You'll need at least 3.55 gears (3.73's would be better) to effectively use it.....Cliff
Old 07-04-2005, 11:17 AM
johnsma22's Avatar
johnsma22 johnsma22 is offline
Are you planning on running racing fuel in your iron headed 10:1 cr motor to avoid detonation?
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 07-04-2005, 11:22 AM
johnsma22's Avatar
Cliff, What would be the effect of running the above combo (400 ci 228/235 cam with 3.23 gears and 4 speed)? I only ask because I am in the process of building a similar motor (eheads) for my 76 T/A and have a 3.23 8.5 10 bolt rear.
John
