Old 07-23-2005, 08:17 PM
WarbirdTA's Avatar
WarbirdTA WarbirdTA is offline
Help!
I haven't ran my 1979 403 Olds powered Trans Am for about 2 years now, and I want to get it running again.
I plan on pulling the plugs, shooting WD-40 into the cylinders, and pulling the distributor and using a oil pump primer rod to send oil throughout the engine.
My problem is I can't find an oil priming rod for an Olds 403.
Would a Pontiac one work? I can borrow a friend's if it does.
Anything else I need to know/do?
Thanks,
George
Old 07-26-2005, 07:09 AM
tom8461 tom8461 is offline
Weld a 5/16" socket to a rod and put in a drill chuck. Make sure you weld it cause if it falls off.................
Old 07-26-2005, 05:02 PM
JSAauto's Avatar
JSAauto JSAauto is offline
I know with Chevrolet, if you take the dist housing out, you never get oil to one side of the engine. I forget if olds is the same way. But if you don't have an oil priming tool, usually cranking the motor with a battery charger on and off for a couple of minutes will get oil to most of the engine and valve train. And if it doesn't, it'll get there quick once the engine starts.
Old 07-26-2005, 07:51 PM
Bandit79403Dave Bandit79403Dave is offline
You can use a socket on the end of the extension approach...it works fine for the Olds 403. Do not crank the motor over with the starter unless you plan on replacing your cam anyway...chances are the lifters have bled down and there is no cushion of oil between the lobes and the cam...if its dry in there, you'll flatlobe the cam. The extension will be good. Good luck!!
BanditDave
403 afficionado...made it my personal quest to maximize the power potential of the 403.
www.fcrperformance.com
Old 07-27-2005, 07:32 AM
WarbirdTA's Avatar
Thanks for the info!
One more question.
Is the Olds engine like the Pontiac engine. Do I go counter-clockwise to spin the oil pump?
Oh ya, so aPontiac oil priming rod won't work for the Olds engine? I can borrow a Pontiac rod.
Thanks,
George
Old 07-27-2005, 09:09 AM
Junqueboi Junqueboi is offline
I do know that the Olds distributor turns opposite of that of a Chevrolet. When you put the plug wires on, you wire the plugs in the firing order (18436572) counterclockwise.
I *THINK* you spin the drill in reverse.
Someone please clarify as I'm about to do this same thing to a '67 Olds 425.
Old 07-27-2005, 12:51 PM
Boiler Boiler is offline
Olds is counter clock wise
Old 08-03-2005, 05:00 PM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
ANy luck getting it to fire over>?
72 Lemans
